Home » RBC Forums » General Discussion » SBCv2 - SRAM_512K
SBCv2 - SRAM_512K [message #1097] Thu, 08 September 2016 05:07 Go to next message
trick-1 is currently offline  trick-1
Hi Folks,
I am building up an SBCv2 Card and wanted to find out what component is used for the 512K SRAM. For the life of me I can't find a part number in the schematic, board pdf or part list beyond SRAM_512KO. If anyone knows what it is that would be greatly appreciated.
Richard
Re: SBCv2 - SRAM_512K [message #1099 is a reply to message #1097] Thu, 08 September 2016 05:44 Go to previous messageGo to next message
computerdoc is currently offline  computerdoc
For the 512KB SRAM, I usually use the AS6C4008N-55PCN 4Mbit 512KB Static Ram chip. Here is the page on Digikey.com
< http://www.digikey.com/product-detail/en/alliance-memory-inc /AS6C4008-55PCN/1450-1027-ND/4234586>
On that page is a link to the datasheet.
Kip Koon
Re: SBCv2 - SRAM_512K [message #1102 is a reply to message #1099] Thu, 08 September 2016 14:50 Go to previous messageGo to next message
thanks for that
Re: SBCv2 - SRAM_512K [message #1103 is a reply to message #1102] Thu, 08 September 2016 23:40 Go to previous messageGo to next message
You are quite welcome trick-1.
I am beginning an SBC v2 build myself and I have been wondering what is the part numbers for the best, fastest version of the 16550, the 40-pin variety, and for the Z80. I have heard of the Z80A and Z80B. Is the Z80B the best one? Are there other variations on these parts that are better. I'd like to make this board the best, fastest, and most feature rich it is capable. Thank you in advance for your help.
Kip Koon
Re: SBCv2 - SRAM_512K [message #1104 is a reply to message #1103] Fri, 09 September 2016 00:14 Go to previous messageGo to next message
These are currently available, some more so than others ;-p
NMOS Z0840004 - 4 MHz
Z0840006 - 6.17 MHz
Z0840008 - 8 MHz
CMOS Z84C0006 - DC to 6.17 MHz
Z84C0008 - DC to 8 MHz
Z84C0010 - DC to 10 MHz
Z84C0020 - DC to 20 MHz
success RHK
Re: SBCv2 - SRAM_512K [message #1105 is a reply to message #1104] Fri, 09 September 2016 08:08 Go to previous messageGo to next message
The parts list specifies a 4 Mhz oscillator for CPU_CLOCK - it's not clear to me if anyone has run the SBC_v2 faster than that.
This page on the wiki archive might be useful - Sergey mentions using an 8MHz CPU chip - https://retrobrewcomputers.org/n8vem-pbwiki-archive/0/358453 34/48860639/35845544/38298574/index.htm
Re: SBCv2 - SRAM_512K [message #1106 is a reply to message #1104] Fri, 09 September 2016 08:22 Go to previous messageGo to next message
Thank you so very much for the part numbers RHK. I decided to order a couple Z84C0020 chips - one for the board and another for a spare. I always buy one extra chip especially when they are coming from so far away and when they are also new old stock. I really appreciate it.
Kip Koon
Re: SBCv2 - SRAM_512K [message #1107 is a reply to message #1105] Fri, 09 September 2016 10:12 Go to previous messageGo to next message
SBC v1 and v2 have both been run up to 12Mhz. I was unable to run at 16Mhz.
Both boards use 74LS-ttl exclusively.
82C55 should be the NEC "-2" version. UART, TL16C550-? used. ? = A or C.
The Alliance memory chip is the fastest, and cheapest. Less than $6; prices vary month to month.
Re: SBCv2 - SRAM_512K [message #1109 is a reply to message #1107] Sat, 10 September 2016 08:53 Go to previous messageGo to next message
Jonas is currently offline  Jonas
I run my SBC v2 at 20MHz. I have built it with ALS and F-logic and Intersil/Harris CP82C55A. Tested with PPISD and PropIO. I have not tested the board at higher freq than 12MHz with DiskIO v3, Dual SD or Dual IDE.
--Jonas
Re: SBCv2 - SRAM_512K [message #1110 is a reply to message #1109] Sat, 10 September 2016 09:03 Go to previous messageGo to next message
Thanks for all the good info about speeds guys! Will make sure it ends up on the wiki eventually.
Re: SBCv2 - SRAM_512K [message #1112 is a reply to message #1110] Sun, 11 September 2016 22:42 Go to previous messageGo to next message
briano is currently offline  briano
If you are going to use the SBC V2 with a DiskIO v3 floppy controller board - you will need to run it at 8MHz minimum to make a 1.44Mb floppy drive work.
At 4MHz a 1.44Mb drive can only be made to work with 720kB floppy media (1.44Mb HD floppies have a higher data transfer rate that the Z80 can't keep up with at 4MHz).
This little nugget of information is buried deep in the old forum archives and threw me off for a few weeks until I found it.
I changed to a 8MHz crystal, but the z80A CPU struggled and was generally unreliable. Put in a 10MUz rated Z80 and it all ran nicely - 1.44Mb floppy now working correctly.
I stayed with the same LS chips I had already installed - no problems seen and it is a very stable system considering I was the one building it....
Re: SBCv2 - SRAM_512K [message #1116 is a reply to message #1112] Tue, 13 September 2016 15:11 Go to previous messageGo to next message
1.44MB drive is 500Kbits/second or 64 clocks at 4MHz
With a sufficiently tight driver loop it can in theory be done (just about) if your FDC has a FIFO
B = 0, C = data register
HL = buffer
l1: in a,(FDC_ST) 11
add a 4
jr nc,l1 7/12
add a 4
jp p, error 10
ini 16
jp nz,l1 10
58 clocks
for 512 byte sectors you have to repeat the code block twice, not enough time to do another loop!
In theory it will work without a FIFO but I'm not sure you'll quite make the first data read fast enough after the status changes in all cases. The only way I know to do the status bit wait faster involves an MMIO address the byte after RAM. The RAM ends JP FF and the mmio causes it to jump to itself until an error or status change when it jumps to a different xxFF.
Alan
Re: SBCv2 - SRAM_512K [message #1122 is a reply to message #1116] Wed, 14 September 2016 04:53 Go to previous messageGo to next message
Yes, no doubt it could be done on the SBC V2 at 4MHz.
For my case I was happy to use the existing rom floppy support so was simpler to change the crystal and run at 8MHz.
Re: SBCv2 - SRAM_512K [message #1147 is a reply to message #1122] Sat, 17 September 2016 06:22 Go to previous messageGo to next message
I noticed that D2 is just labeled "Diode". Is this a small signal diode or an 1/8 watt rectifier diode?
Kip Koon
Re: SBCv2 - SRAM_512K [message #1154 is a reply to message #1147] Sun, 18 September 2016 13:28 Go to previous message
1N4148 or equivalent.
possible alt.
1N914
BAT43
1N5818
[Updated on: Sun, 18 September 2016 13:28]
Previous Topic: Interconnecting CP/M boards
Next Topic: Multicomp FPGA in Papilio Duo Platform (Xilinx Spartan-6)
Current Time: Thu Dec 18 11:26:35 PST 2025
Total time taken to generate the page: 0.01426 seconds
