ASCII���user comment
Currently supporting: CP/M 2.2, Dos+ 2.5, ZSDOS 1.1/ZCPR 2, CP/M 3, ZPM3 and NASCOM “ROM” BASIC 4.7
SBC-2G-512k
Currently supporting: CP/M 2.2, Dos+ 2.5, ZSDOS 1.1 / ZCPR 2, MP/M, CP/M 3, ZPM3 and NASCOM “ROM” BASIC 4.7
An FPGA implementation of the earlier mentioned Z80 system. Because the configuration supports a 50 Hz interrupt signal, MP/MII was added to the set of supported operating systems.
The system is laid out to run on Altera Cyclone II (EP2C5) miniboard
The board shown is a prototype of a compact version of a CycloneII-c board with added serial interface connectors (4 in total)
MC-2G-1024k
In answer to popular demand: yes it works on a Cyclone IV too
These are the VHDLs I use,
Cyclone IV.zip
The board shown is a prototype compact version of James Moxham's work with 4 serial interface connectors.
This ia a fork of Takashi TOYOSHIMA's CP/Mega88 project (https://github.com/toyoshim/cp-mega88), only focussing on the AVR implementation.
The project features an Intel 8080 emulator, running in an ATmega88 AVR, in a virtual machine which runs CP/M 2.2 and 3.0. (dual boot)
This is a work in progress. Although the system is functional, it is not yet finished. Inside you will find all the files you need to build the system
ASCII���user comment On Serial - USB interfaces
builderpages/rhkoolstar/start.1503495214.txt.gz · Last modified: 2017/08/23 09:33 by rhkoolstar
