ASCII���user comment
Currently supporting: CP/M 2.2, Dos+ 2.5, ZSDOS 1.1/ZCPR 2, CP/M 3 and ZPM3
SBC-2G-512k
Currently supporting: CP/M 2.2, Dos+ 2.5, ZSDOS 1.1 / ZCPR 2, MP/M, CP/M 3, ZPM3 and NASCOM “ROM” BASIC 4.7
An FPGA implementation of the earlier mentioned Z80 system. Because the configuration supports a 50 Hz interrupt signal, MP/MII was added to the set of supported operating systems. Also “ROM” basic returns (in a way)
The system is laid out to run on Altera Cyclone II (EP2C5) miniboard
The system shown is a prototype of a compact version of a CycloneII-c board with added serial interface connectors (4 in total)
MC-2G-1024k
In answer to popular demand: yes it works on a Cyclone VI too
These are the VHDLs I use,
Cyclone VI.zip
The board shown is a prototype compact version of James Moxham's work with 4 serial interface connectors.
On Serial - USB interfaces
builderpages/rhkoolstar/start.1475671746.txt.gz · Last modified: 2016/10/05 08:49 by rhkoolstar
