ASCII���user comment
SBC-2G-512k
An FPGA implementation of the earlier mentioned Z80 system. Because the configuration supports a 50 Hz interrupt signal, MP/MII was added to the set of supported operating systems. Also “ROM” basic returns (in a way)
The system will run on Altera Cyclone II (EP2C5) as well as Cyclone IV (EP4CE6) miniboards
The system shown is a prototype of a compact version of a CycloneII-c board with added serial interface connectors (4 in total)
MC-2G-1024k
In answer to popular demand: yes it works on a Cyclone VI too
These are the VHDLs I use,
Cyclone VI.zip
The board shown is a prototype compact version of James Moxham's work with 4 serial interface connectors.
On Serial - USB interfaces
builderpages/rhkoolstar/start.1474111306.txt.gz · Last modified: 2016/09/17 07:21 by rhkoolstar
