ZZRCC I2C Interface
ZZRCC has a 4-pin I2C connector and a bit-bang register in CPLD that controls the I2C signals. The following is an introduction to using the I2C function.
I2C Connector Definition
The pin assignments of the I2C connector from left-to-right are
–annotated picture here— SDA, SCL, GND VCC
I2C Register in CPLD
I/O address is 0x9E
SDA is data bit 0, open collector with external 2.4K pull up resistor
SCL is data bit 1, CMOS output, no external pull up resistor.
Data bit 2 to 7 are don't care
Both SDA and SCL are high at reset.
I2C Bit Bang Example
I2C Start command
i2cs: ; I2C START command ; SCL is D[1], SDA is D[0] ld a,3 out (I2C),a ;set SCL and SDA high nop nop ld a,2 out (I2C),a ;START nop nop nop nop ld a,0 out (I2C),a ;clock low ret
Bit bang a byte of data to I2C bus
;pass data in regA ;SCL is D[1], SDA is D[0], other bits are don't care ;roll 8 bit data around through carry flag, take care of not alter carry flag ;with set/res instruction SCL can be wiggled without changing rest of the data ;slave acknowledge is not checked so no error message when slave is not present push bc ld b,8 ;8 passes for 8 bits rla ;msb into carry wi2cN1: rla ;in first pass: msb into bit0 (SDA), carry in bit 1 (SCL) res 1,a ;make sure clock is low out (I2C),a ;change data while clock is low set 1,a ;clock is high out (I2C),a nop res 1,a ;clock is low out (I2C),a djnz wi2cN1 ld a,1 ;slave acknowledge cycle out (I2C),a ld a,3 out (I2C),a ld a,1 ;no checking of slave acknowledge out (I2C),a pop bc ret
I2C Stop Command
i2cp: ;I2C STOP command ; SCL is D[1], SDA is D[0] ld a,0 out (I2C),a ld a,2 out (I2C),a nop nop nop nop ;data goes high while clock high (STOP) ld a,3 out (I2C),a ret
