builderpages:plasmo:t68krc [2019/08/11 08:02]
builderpages:plasmo:t68krc [2020/09/30 00:49] (current)
Line 72: Line 72:
   * 11/23/17 update: The original design files posted were incorrect. This is the correct version of the design files. Altera EPM7128 design files Designs are created in Quartus 8.1, should be compatible with later version of Quartus. Designs are entirely in schematics. Schematic in PDF format. {{:​boards:​sbc:​tiny68k:​released_epm7128_program_binary.zip|Programming binary}} ​ in .pof format. ** <- need revision**   * 11/23/17 update: The original design files posted were incorrect. This is the correct version of the design files. Altera EPM7128 design files Designs are created in Quartus 8.1, should be compatible with later version of Quartus. Designs are entirely in schematics. Schematic in PDF format. {{:​boards:​sbc:​tiny68k:​released_epm7128_program_binary.zip|Programming binary}} ​ in .pof format. ** <- need revision**
-CP/​M-68K ​<​del>​{{:​boards:​sbc:​tiny68k:​tinybios_r4.zip|BIOS for T68KRC,​}} ​ </​del>​T68KRC BIOS, updated 8/11/19 with correct TPA size.+<​del>​{{:​boards:​sbc:​tiny68k:​tinybios_r4.zip|BIOS for T68KRC,​}} ​ </​del>​obsoleted CPM68K BIOS for T68KRC,
 +{{:​builderpages:​plasmo:​t68krc:​t68kbios_r1.zip|T68KRC BIOS}}, updated 8/11/19 with correct TPA size.
 CP/M-68K {{:​boards:​sbc:​tiny68k:​cpm15000.zip|CPM v1.3}} CP/M-68K {{:​boards:​sbc:​tiny68k:​cpm15000.zip|CPM v1.3}}
Line 97: Line 99:
 ==== Creating a new CF disk ==== ==== Creating a new CF disk ====
-Procedure for creating a new CF disk+Procedure for [[:​builderpages:​plasmo:​t68krc:​newcf|creating a new CF disk]]
builderpages/plasmo/t68krc.1565524966.txt.gz · Last modified: 2019/08/11 08:02 by plasmo
