Next revision Both sides next revision
builderpages:plasmo:t68krc [2019/08/11 08:02]
Line 72: Line 72:
   * 11/23/17 update: The original design files posted were incorrect. This is the correct version of the design files. Altera EPM7128 design files Designs are created in Quartus 8.1, should be compatible with later version of Quartus. Designs are entirely in schematics. Schematic in PDF format. {{:​boards:​sbc:​tiny68k:​released_epm7128_program_binary.zip|Programming binary}} ​ in .pof format. ** <- need revision**   * 11/23/17 update: The original design files posted were incorrect. This is the correct version of the design files. Altera EPM7128 design files Designs are created in Quartus 8.1, should be compatible with later version of Quartus. Designs are entirely in schematics. Schematic in PDF format. {{:​boards:​sbc:​tiny68k:​released_epm7128_program_binary.zip|Programming binary}} ​ in .pof format. ** <- need revision**
-CP/M-68K <​del>​{{:​boards:​sbc:​tiny68k:​tinybios_r4.zip|BIOS for T68KRC,​}} ​ </​del>​ +CP/M-68K <​del>​{{:​boards:​sbc:​tiny68k:​tinybios_r4.zip|BIOS for T68KRC,​}} ​ </​del>​T68KRC BIOS, updated 8/11/19 with correct TPA size.
-T68KRC BIOS, updated 8/11/19 with correct TPA size.+
 CP/M-68K {{:​boards:​sbc:​tiny68k:​cpm15000.zip|CPM v1.3}} CP/M-68K {{:​boards:​sbc:​tiny68k:​cpm15000.zip|CPM v1.3}}
builderpages/plasmo/t68krc.txt · Last modified: 2020/09/30 00:49 by plasmo
