T68KMB, Tiny68K with RC2014 Expansion Busses
T68KMB is T68KRC with 3 RC2014 expansion busses added. It is software compatible with T68KRC.
www.retrobrewcomputers.org_lib_plugins_ckgedit_fckeditor_userfiles_image_builderpages_plasmo_t68kmb_t68kmb.jpg
Motorola 68000 CPU
MC68681 DUART, port A is the console operating at 38400 baud, 8N1, with CTS/RTS hardware handshake.
Altera EPM7128 CPLD contains the glue logic:
State machine to load 32K serial flash when powered up or with a reset,
DRAM controller for the 2-megabyte DRAM,
Hidden CAS-before-RAS refresh in hardware, no software overhead required,
memory decoder,
Interrupt controller,
Bus Error watchdog timer,
8-16 MHzoscillator (only 8 MHzoperation is tested)
32Kbyte serial flash, 24C256 as the boot device.
Second 32K serial flash that can be programmed in-situ and serves as the alternate boot device with just one jumper change.
44-pin edge connector interfaces to a low-cost IDE-CF module
HY5118164 1Mx16 DRAM
I/O expansion port compatible with RC2014 I/O bus interface.
7-segment LED display as visual indicator of board operations.
Target for CP/M-68K ver 1.3
100mm x 76mm 2-layer pc board
www.retrobrewcomputers.org_lib_plugins_ckgedit_fckeditor_userfiles_image_builderpages_plasmo_t68kmb_t68kmb_annotated.jpg
Schematic
Gerber photoplots
CPLD design
T68KMB software is compatible to T68KRC. Please refer to software section of T68KRC.
builderpages/plasmo/t68kmb.1601381819.txt.gz · Last modified: 2020/09/29 08:16 by plasmo
