G8PPBase + 6502
This is a two-board configuration consists of a G8PP in baseline configuration and a simple 6502 board on RC2014 backplane.
6502 CPU Card
Prototype 6502 CPU Card
This is a prototype of the 6502 CPU card. It is superseded by the PC board version.
Schematic of prototype 6502 CPU card
RC2014 Signal Definition
The following RC2014 signals are redefined for G8PPBase+6502
- RC2014 Pin 19 (nM1) — SYNC (6502 pin 7)
- RC2014 Pin 23 (nMREQ) — RWB (6502 pin 34)
- RC2014 Pin 24 (nWR) — Not Assigned
- RC2014 Pin 25 (nRD) — Not Assigned
- RC2014 Pin 26 (nIORQ) — VPB (6502 pin 1)
- RC2014 Pin 37 (Spare 1) — BE (6502 pin 36)
- RC2014 Pin 38 (Spare 2) — RDY (6502 pin 2)
- RC2014 Pin 39 (Spare 3) — NMIB (6502 pin 6)
G8PP Baseline Configuration
G8PPBase+6502
Serial Bootstrap, move jumper to 'Serial Bootstrap' position, load Tinyload.bin as binary file (check the 'Binary' box in TeraTerm), Tinyload will sign on with '12/26/18'
6502 Monitor
EhBASIC by Lee Davison, load 'MIN_MON.HEX' as hex file (do not check the 'Binary' box in TeraTerm), type 'G e82a' after load is completed. EhBasic will respond with '6502 EhBASIC [C]old/[W]arm ?'
ASCIIART benchmark for EhBasic.
Manuals and Instructions
Getting Started with G8PPBase+6502 ←configure altera epm7128, load bootstrap, load 6502 monitor, load & run EhBASIC
6502 Monitor manual
