2650 Max v1
Welcome to my build of Michael Cvetanovski 's 2650 Max SBC.
More information here:
https://sites.google.com/site/gogleoops/2650-max
Micheal has some other interesting projects on his OLD Micros site as well, check it out:
This build was inspired by my very first computer an Electronics Australia 2650 system.
https://archive.org/stream/EA1978/EA%201978-05%20May#page/n57/mode/2up
I don't have that system anymore but still have the CPU, PROM and transformer. The CPU will be using in this build - nearly 40 years old now.
Read all about an awesome remake of this system I just stumbled upon:
http://www.postincrement.net/2650-remake-finished-and-working/
- 1Mhz 2650 CPU.
- NVRAM chip used for RAM and ROM storage. The ROM area is “write protected” by the GAL logic.
- PIPBUG monitor available.
- MWBASIC monitor available.
- TTL level 300 baud direct interface to pipbug monitor and mwbasic.
- Three 8 bit input/output ports.
- TTL level serial port.
Item | Qty | Description |
2650, 8255 socket, | 2 | 40pin DIP socket |
DS1245A socket | 1 | 32pin DIP socket |
PAL socket | 1 | 24pin narrow DIP socket |
MC68B50 socket | 1 | 24pin DIP socket |
IC1 | 1 | Signetics 2650 microcomputer |
IC2 | 1 | i8255 PPI (programmable peripheral interface) |
IC3 | 1 | Maxim DS1245Y-70 128Kb non-volatile memory |
IC4 | 1 | GAL22V10 (preprogrammed) |
IC5 | 1 | MC68B50 ACIA |
IC6 | 1 | SN74LS14N hex inverter with schmitt trigger |
Y2 | 1 | 1Mhz DIP14 5V active crystal oscillator |
Y3 | 1 | 1.8432Mhz DIP14 5V active crystal oscillator |
R1, R2, R4, R6, R7, R8 | 6 | 4K7 resistor |
R5 | 1 | 47R resistor |
R9 | 1 | Current limit resistor 1K8, 2K2 etc |
C1 | 1 | 47uF tantalum capacitor |
C2, C3, C4, C5, C6, C7, C9, C10 | 8 | 0.1uF ceramic capacitors 2.54mm |
D1 | 1 | 3mm LED |
Reset | 1 | PCB mount push button |
PortA, PortB, PortC, invgates | 4 | 2x5pin male pin header 2.54mm |
Comms, A15, A16, E | 4 | 3 pin male header 2.54mm |
H1, Ucomms | 2 | 4 pin male header 2.54mm |
Assembly Instructions
If you have a complete set of parts, here's a suggested assembly guide
- All IC sockets
- Resistor R5
- Resistor R9
- All other resistors.
- 3mm LED - polarity important
- Reset SW1
- All 0.1uF capacitors
- Capacitor C1 - polarity important
- Crystal Y2, Y3
- Bend up pin 2 of SN74LS14N up solder in.
- All 2x5pin headers
- All 3pin and 4pin headers
- Power / reset connector
- Populate all IC sockets.
I found using a dab of superglue on the pin headers helped keep them in place for soldering. I also recommend using gold plated pin headers as the un-plated ones solder poorly and leave a unsatisfactory finish.
If you are using the v1 PCB as I am there are four modifications to be made which are documented on the designers site, see link above.
Resources
2650 Microcomputer
RS232 level logic circuits for the 68B50
- All IC sockets
- Resistor R5
- Resistor R9
- Reset SW1
- Crystal Y2, Y3
Resources
2650 Microcomputer
Memory Map - 4 x 32Kb blocks
0X00000-0X20000 | A15 | A16 | |
0X00000 | 0X07FFF | L | L |
0X08000 | 0X0FFFF | H | L |
0X10000 | 0X17FFF | L | H |
0X18000 | 0X20000 | H | H |
