Z-Berry
Z-Berry is the smallest Z80 based computer ever built.
Original Z80 CPU, modern RAM and ROM with 74xxx discrete logic ICs.
Right place to discover Z-Berry https://sites.google.com/view/zberry
Features:
Z80 CPU running at 10MHz (20MHz possible)
32kB ROM
512kB RAM
microSD card storage
1 output full 8 bit-port
1 input full 8-bit port
3 independent input pins
4 independent output pins
serial interface (57 600 Bd)
I2C bus
SPI bus
PS/2 keyboard connector
beeper
software driven LED
reset button
connector with almost full Z80 bus
5V powered via micro-USB connector
pluggable daughter board with real-time clock or OLED display
total 17 IC chips
two layers PCB
credit card sized (85x56mm)
fits Raspberry Pi cases (but only a few of them fits perfectly)
firmware with SD card support
boards/sbc/z-berry.txt · Last modified: 2017/04/15 10:38 by m1
