SBC V2 (web pages currently being reformatted b1ackmai1er 1/12/2020)
Previously known as the N8VEM SBC, development began in 2006 wth V1 and is currently still in development.
For most people, the SBC-V2-004 offers the most convenience and functionality.
  • 4Mhz+ Zilog Z80 CPU.
  • Up to 512Kb paged SRAM.
  • Up to 1Mb EPROM or 512Kb Flash ROM.
  • Serial Interface.
  • IDE interface.
  • Real Time Clock.
  • Onboard sound.
  • Standard ECB bus interface.
  • Reset button.
  • Status LED.
Software Support
ROMWBW BIOS featuring:
  • CP/M / ZSDOS
  • RAM & ROM disk support.
  • Prebuild disk images
  • RAMFLOPPY
  • VDU
  • CVDU
  • VGA3
  • Zilog Peripherals
  • USB FIFO
  • Disk I/O
  • 4PIO
  • SCG
  • DSKY
  • DUAL SD CARD
  • MF-PIC
Version History
VersionDetailsKey feature
SBC V1Initial versionRuns as Single Board Computer or on Euro Card Bus.
SBC V2-003Enhanced versionBattery backed RAM support, Serial jumper options, RAM and ROM configuration options.
SBC V2-004Extended versionIDE connector, sound, Clock speed control, Super capacitor for RAM and RTC backup.
SBC V2-005In development1Mb Flash support.
REAL TIME CLOCK (RTC)
Loading CPM...
CP/M-80 Version 2.2C for the N8VEM, October 2008
Run XM from A drive, this downloads file to B drive
A>rtc
Start RTC Program
RTC: Version 1.0
RTC: Commands: E)xit T)ime st(A)rt S)et R)aw L)oop C)harge N)ocharge D)elay I)nit G)et P)ut H)elp
RTC: trickle charger disabled.
RTC>
RTC.COM is part of Wayne Warthen's ROMWBW package.
One Bit Input Port
SBC_std_cust.asm
CRTACT        .SET    TRUE           ; CRT ACTIVATION AT STARTUP
VDAEMU        .SET    EMUTYP_ANSI    ; DEFAULT VDA EMULATION (EMUTYP_TTY, EMUTYP_ANSI, ...)
boards/sbc/sbc_v2/start.1606819145.txt.gz · Last modified: 2020/12/01 05:39 by b1ackmai1er
