SBC V2
Previously known as the N8VEM SBC, development began in 2006 wth V1 and is currently still in development.
For most people, the SBC-V2-004 offers the most convenience and functionality.
  • 4Mhz+ Zilog Z80 CPU.
  • Up to 512Kb paged SRAM.
  • Up to 1Mb EPROM or 512Kb Flash ROM.
  • Serial Interface.
  • IDE interface.
  • Real Time Clock.
  • Onboard sound.
  • Standard ECB bus interface.
  • Reset button.
  • Status LED.
Software Support
ROMWBW BIOS featuring:
  • CP/M / ZSDOS
  • RAM & ROM disk support.
  • Prebuild disk images
Version History
VersionDetailsKey feature
SBC V1Initial versionRuns as Single Board Computer or on Euro Card Bus.
SBC V2-003Enhanced versionBattery backed RAM support, Serial jumper options, RAM and ROM configuration options.
SBC V2-004Extended versionIDE connector, sound, Clock speed control, Super capacitor for RAM and RTC backup.
SBC V2-005In development1Mb Flash support.
Jumper Settings
Board ReferenceJumper Description
Jumper setting
1-2
Jumper setting
2-3
Notes
JP1 Battery backup X
Installed - allows you to use the common battery backup on the ECB bus (pin A24).
Not installed - means either a local battery is used or no battery backup at all.
JP2One bit input portX
Installed - enables the one bit input port. This is currently
unused although could be used for external input if desired like a button or other things.
Not installed - disables the one bit input port.
K1U2 EPROM chip pins (32-pin or 28-pin)X * 32-pin EPROM used in U2 (ex. 27C080 1MBx8 EPROM) - default
X28-pin EPROM used in U2 (ex. 27C256 EPROM)
K2UART side hardware handshaking (DSR, CTS)X * DSR (this should be paired with K3 - DTR) - default
XCTS (this should be paired with K3 - RTS)
K3UART side hardware handshaking (DTR, RTS)X * DTR (this should be paired with K2 - DSR) - default
XRTS (this should be paired with K2 - CTS)
K4Serial side hardware handshaking (DSR, CTS)X * DSR (this should be paired with K5 - DTR) - default
XCTS (this should be paired with K5 - RTS)
K5Serial side hardware handshaking (DTR, RTS)X * DTR (this should be paired with K4 - DSR) - default
XRTS (this should be paired with K4 - CTS)
K6U2 chip type (27C080 EPROM, 29C040 flash)X * 27C080 EPROM used in U2 - default
X29C040 flash used in U2
K7U23 SRAM (512K or 128K)X * 512K chip used in U23 - default
X128K chip used in U23
K8U2 chip type (27C080 EPROM, 29C040 flash)X * 27C080 EPROM used in U2 - default
K9Parallel Port power control (pin 25)X * GROUND - default
XVCC ( WARNING - this setting will send VCC power down pin 25 of the parallel port which may potentially damage connected device)
K10MCPL (Memory Page Config Latched)X * 32K upper RAM fixed/32K lower RAM switchable memory map - default
X48K upper RAM fixed/16K lower RAM switchable memory map (banked)
K11MCPL (Memory Page Config Latched)X * 32K upper RAM fixed/32K lower RAM switchable memory map - default
K12Bus Interrupt (pin A23)X * Internal UART interrupt - default
XExternal ECB interrupt
K13ECB/Kontron Reset configurationX * ECB legacy: pin C-31 is Reset OUT to peripherals - default
X
Kontron compatible: pin C-31 is Reset IN from a SPST pushbutton pin C-26 is Reset OUT to peripherals.
N.B.: All boards in a system must use the same setting. Older boards don't have this jumper; hence, 1-2 is specified as the “default” setting. Newer systems should use the Kontron setting, since the newer backplanes have the Reset IN connector for pin C-31. (JRC 2015-7-6)
* = default setting
Serial Cable Instructions
IDC-10 sideDE-9 side
24
33
52
76
95
Flow control considerations:
In the absence of flow control, guidelines for baud rate settings are:
4Mhz CPU Crystal - 38400 baud
8Mhz CPU Crystal - 57600 baud
REAL TIME CLOCK (RTC)
Loading CPM...
CP/M-80 Version 2.2C for the N8VEM, October 2008
Run XM from A drive, this downloads file to B drive
A>rtc
Start RTC Program
RTC: Version 1.0
RTC: Commands: E)xit T)ime st(A)rt S)et R)aw L)oop C)harge N)ocharge D)elay I)nit G)et P)ut H)elp
RTC: trickle charger disabled.
RTC>
RTC.COM is part of Wayne Warthen's ROMWBW package.
One Bit Input Port
SBC_std_cust.asm
CRTACT        .SET    TRUE           ; CRT ACTIVATION AT STARTUP
VDAEMU        .SET    EMUTYP_ANSI    ; DEFAULT VDA EMULATION (EMUTYP_TTY, EMUTYP_ANSI, ...)
Boot "BEEP" modification
There is no inbuilt sound on the SBC V2-003 board. Complex sound output can be achieved with the ECB-SCG (Sprite-Colour-Graphics) board.
Rudimentary sound support can be add the SBC V2 by utilizing one of the unused outputs of the RTC interfacing latch and connecting a simple amplifier to this output.
On U18 74LS174 connect a ground wire from pin 8 and a signal wire from pin 2 to an amplifier. Generic LM386 amplifiers are available from many sources and work well.
With this addition and the SPKENABLE setting set to TRUE in ROMWBW, the SBC V2 will issue a beep sound on bootup.
A transistor speaker driver has been incorporated in the SBC-V2-004 so a speaker can be connected directly to the board.
Sound support has been added to NASCOM BASIC in ROMWBW 2.9.2-pre.17:
PLAY O,N,D
Where:
 O = OCTAVE 0-8
 N = NOTE 0-11
 D = DURATION 1-8 (8ths of a second)
Example:
 Middle C for one second = PLAY 4,0,8
boards/sbc/sbc_v2/start.1606312737.txt.gz · Last modified: 2020/11/25 08:58 by b1ackmai1er
