SBC V2
- 4Mhz Zilog Z80 CPU
- Up to 512Kb paged SRAM (: Add link to the paging description)
- Up to 1Mb EPROM or FLASH ROM.
- Serial Interface (16550 Uart)
- Parallel interface (8255), can be extended to support IDE interface via small board
- Real Time Clock (DS1302)
- Battery backup for RTC and SRAM.
- Standard ECB bus interface
- Standard PC drive connector power supply interface using +5V only
- Reset button with external connector
- Status LED
Board
The latest SBC V2 schematic is available here: :boards:sbc:sbc_v2:sbc-v2-003-sch.pdf
Also, here's the board's PCB layout: :boards:sbc:sbc_v2:sbc-v2-003-brd.pdf
Kicad files for board manufacture: :boards:sbc:sbc_v2:ecb_sbc_v2-003-kicad.zip
A description of the circuit operation can been seen here: http://obsolescence.wixsite.com/obsolescence/the-n8vem-sbc
Errata
There is an error in the board layouts of sbc-v2-003 compared to the original schematic that results in the external reset not working in Kontron mode.
To configure the board to work in Kontron mode with the external reset coming from the backplane the following workaround can be made.
- Pin 3 on K13 needs to be jumpered to Pin 2 of P6 (Reset switch jumper) - this connects the backplane reset input pin (c31) to the reset circuit input.
- Pin 1-2 needs to be jumpered on K13 - this connects the /reset circuit output to the backplane reset out pin(c26).
Jumper Settings
Board Reference | Jumper Description | Jumper setting 1-2 | Jumper setting 2-3 | Notes |
JP1 | Battery backup | X | Installed - allows you to use the common battery backup on the ECB bus (pin A24). Not installed - means either a local battery is used or no battery backup at all. |
JP2 | One bit input port | X | Installed - enables the one bit input port. This is currently unused although could be used for external input if desired like a button or other things. Not installed - disables the one bit input port. |
K1 | U2 EPROM chip pins (32-pin or 28-pin) | X * | 32-pin EPROM used in U2 (ex. 27C080 1MBx8 EPROM) - default | |
X | 28-pin EPROM used in U2 (ex. 27C256 EPROM) | |||
K2 | UART side hardware handshaking (DSR, CTS) | X * | DSR (this should be paired with K3 - DTR) - default | |
X | CTS (this should be paired with K3 - RTS) | |||
K3 | UART side hardware handshaking (DTR, RTS) | X * | DTR (this should be paired with K2 - DSR) - default | |
X | RTS (this should be paired with K2 - CTS) | |||
K4 | Serial side hardware handshaking (DSR, CTS) | X * | DSR (this should be paired with K5 - DTR) - default | |
X | CTS (this should be paired with K5 - RTS) | |||
K5 | Serial side hardware handshaking (DTR, RTS) | X * | DTR (this should be paired with K4 - DSR) - default | |
X | RTS (this should be paired with K4 - CTS) | |||
K6 | U2 chip type (27C080 EPROM, 29C040 flash) | X * | 27C080 EPROM used in U2 - default | |
X | 29C040 flash used in U2 | |||
K7 | U23 SRAM (512K or 128K) | X * | 512K chip used in U23 - default | |
X | 128K chip used in U23 | |||
K8 | U2 chip type (27C080 EPROM, 29C040 flash) | X * | 27C080 EPROM used in U2 - default | |
K9 | Parallel Port power control (pin 25) | X * | GROUND - default | |
X | VCC ( WARNING - this setting will send VCC power down pin 25 of the parallel port which may potentially damage connected device) | |||
K10 | MCPL (Memory Page Config Latched) | X * | 32K upper RAM fixed/32K lower RAM switchable memory map - default | |
X | 48K upper RAM fixed/16K lower RAM switchable memory map (banked) | |||
K11 | MCPL (Memory Page Config Latched) | X * | 32K upper RAM fixed/32K lower RAM switchable memory map - default | |
K12 | Bus Interrupt (pin A23) | X * | Internal UART interrupt - default | |
X | External ECB interrupt | |||
K13 | ECB/Kontron Reset configuration | X * | ECB legacy: pin C-31 is Reset OUT to peripherals - default | |
X | Kontron compatible: pin C-31 is Reset IN from a SPST pushbutton pin C-26 is Reset OUT to peripherals. N.B.: All boards in a system must use the same setting. Older boards don't have this jumper; hence, 1-2 is specified as the “default” setting. Newer systems should use the Kontron setting, since the newer backplanes have the Reset IN connector for pin C-31. (JRC 2015-7-6) |
* = default setting
Serial Cable Instructions
IDC-10 side | DE-9 side |
2 | 4 |
3 | 3 |
5 | 2 |
7 | 6 |
9 | 5 |
Flow control considerations:
In the absence of flow control, guidelines for baud rate settings are:
4Mhz CPU Crystal - 38400 baud
8Mhz CPU Crystal - 57600 baud
Full list of parts::boards:sbc:sbc_v2:sbc-v2-parts-list.pdf
See here for minimum build and parts substitution guidelines.
REAL TIME CLOCK (RTC)
Loading CPM... CP/M-80 Version 2.2C for the N8VEM, October 2008 Run XM from A drive, this downloads file to B drive A>rtc Start RTC Program RTC: Version 1.0 RTC: Commands: E)xit T)ime st(A)rt S)et R)aw L)oop C)harge N)ocharge D)elay I)nit G)et P)ut H)elp RTC: trickle charger disabled. RTC>
RTC.COM is part of Wayne Warthen's ROMWBW package.
Status LED
A single color or bicolor LED can be installed for the status LED. The LED monitors the status of the HALT line from the Z80 CPU. Consider the color selection and orientation when choosing. A red/green LED is ideal and logically should show green when cpu is running and red when halted. Or in the case of a single colour LED, on when cpu is running and off when halted. It is wise to not fully solder in the LED until the orientation has been checked to confirm the right sequence. Or, you could install a pin header and run flying leads to an LED mounted in a case,
The HALT status can be initiated by booting CP/M and running the DDTZ debugger, loading and executing a HALT instruction.
B>ddtz DDTZ v2.7M by CB Falconer. CPU=Z80 -a100 0100 hlt 0101 -g100
Memory Paging
The SBC can be configured with 128Kb or 512Kb RAM and up to 512Kb ROM. The Z80 processor can only access 64Kb at one time, so the additionally memory is accessed through a memory paging scheme.
The memory paging system can be configured in different ways but the common default is to be set with a fixed 32Kb of RAM set in the top 8000h-FFFFh range and for the bottom 32Kb 0000h-7FFFh being selectable from either the RAM or ROM chips. This 32Kb/32Kb configuration is what is supported by the ROMWBW software package.
Port Map
PPI 82C55 I/O $60-$67
16550 UART $68
RTC LATCH AND INPUT PORT $70
RAM MEMORY PAGER CONFIG LATCH - RAM (WRITE ONLY) $78
RAM MEMORY PAGER CONFIG LATCH - ROM (WRITE ONLY) $7C
Changes from V1
Information regarding V1 can be found here.
