ECB USB FIFO
The FT232H has a separate FIFO (first-in-first-out queue) for the receive and transmit directions. Each FIFO is 1KB in size. Data is transferred to/from the FIFOs over the USB link in blocks of up to 512 bytes. A “send immediate” operation is supported which causes any queued data in the transmit FIFO to be sent over the USB link at the earliest opportunity, otherwise the FT232H may wait a short while to accumulate more data before performing a transfer over the USB link.
ECB I/O Registers
I/O addressRegister use
Write: No effect
Bit (Value)Meaning
0 (0x01)TX_FULL: read-only
0 if interrupts are disabled,
1 if interrupts are enabled.
2 (0x04)INT_TX: read/write
3 (0x08)INT_RX: read/write
4 (0x10)GPIO_IN: read/write
5 (0x20)GPIO_OUT: read-only
6 (0x40)IRQ: read-only
7 (0x80)RX_EMPTY: read-only
ECB Card Jumpers
Schematic
U1, U374LS244TI SN74LS244N (Farnell order code 1739688)
U974AHCT244 (preferred) or 74LS244TI SN74AHCT244N (Farnell order code 1752769)
U674AHCT139 (preferred) or 74LS139ATI SN74AHCT139N (Farnell order code 1741539)
U7, U1174ACT32 (preferred), 74AHCT32 (untested but should work) or 74LS32TI SN74ACT32N (Farnell order code 1739969), TI SN74AHCT32N (Farnell order code 1749941) or TI SN74LS32N (Farnell order code 1740030)
It is possible to build this board with entirely 74LS series logic, and this works well. However slightly higher performance can be achieved by substituting 74AHCT parts for U6 and U9, and 74ACT for U7 and U11. Testing on a Mark IV SBC at 36.864MHz, a board using only 74LS parts requires 2 I/O wait states, whereas with the 74AHCT parts at U6 and U9 the board operates correctly with only 1 I/O wait state. U7 and U11 can use 74ACT32 which also gives a further timing improvement. The forum thread has more information on how the timing improves with CMOS parts. Note that U1, U2 and U3 should always use 74LS as the bus interface benefits from having hysteresis on the inputs to improve noise rejection; the 74LS244 and 74LS245 parts have Schmitt trigger inputs.
Photographs
Example Code
FIFO_BASE       = 0x0C
FIFO_DATA       = (FIFO_BASE+0)
FIFO_STATUS     = (FIFO_BASE+1)
FIFO_SEND_IMM   = (FIFO_BASE+2)
fifo_receive:
        ; Enter with:
        dec de
        inc d
waitrx:
        in a, (FIFO_STATUS)
        dec d
        jr nz, waitrx
        ret
fifo_transmit:
        ; Enter with:
        dec de
        inc d
waittx:
        in a, (FIFO_STATUS)
        dec d
        jr nz, waittx
        ret
fifo_flush:
        ret
I also have a file transfer application for CP/M, FIFOPIPE. Drop me an email (will /at/ sowerbutts.com) if you'd like to try it out.
Software support
RomWBW 2.9.2-pre.3 included driver support for the ecb-usb-fifo board and this can be enabled with the following assembly customizations.
UFENABLE  .SET  TRUE
Inclusion of the driver in RomWBW will result in the board appearing as SIO serial port. The port is virtual in nature and changing serial settings have no affect on it's operation.
RetroBrew HBIOS v2.9.2-pre.3, 2019-08-07
SBC Z80 @ 3.992MHz
0 MEM W/S, 1 I/O W/S, INT MODE 2
512KB ROM, 512KB RAM
UART0: IO=0x68 16550A MODE=38400,8,N,1
DSRTC: MODE=STD Thu 2019-08-08 17:42:23 CHARGE=ON
MD: UNITS=2 ROMDISK=384KB RAMDISK=384KB
USB-FIFO: IO=0x0C
Unit        Device      Type              Capacity/Mode
Disk 0      MD1:        RAM Disk          384KB,LBA
Disk 1      MD0:        ROM Disk          384KB,LBA
Char 0      UART0:      RS-232            38400,8,N,1
Char 1      SIO0:       RS-232            9600,8,N,1
Depending on how many character based ports are in your system, you may be able to use CP/M redirection to access the USB-Fifo port. In order for the the USB-fifo board to be used as the console device it must be set as the first RomWBW CIO device through the FORCECON option.
FORCECON .SET 2
Serial File transfer using the USB-Fifo can be accomplished using Willl Sowerbutts fifo-pipe program or using XModem. XModem requires a customer version to be assembled with USB-Fifo driver overlay.
boards/ecb/usb-fifo/start.1565448623.txt.gz · Last modified: 2019/08/10 10:50 by b1ackmai1er
