ECB USB FIFO
The FT232H has a separate FIFO (first-in-first-out queue) for the receive and transmit directions. Each FIFO is 1KB in size. Data is transferred to/from the FIFOs over the USB link in blocks of up to 512 bytes. A “send immediate” operation is supported which causes any queued data in the transmit FIFO to be sent over the USB link at the earliest opportunity, otherwise the FT232H may wait a short while to accumulate more data before performing a transfer over the USB link.
ECB I/O Registers
I/O address | Register use |
BASE+0 (0x0C) | Read: Remove one byte of data from the receive FIFO Write: Insert one byte of data into the transmit FIFO |
BASE+1 (0x0D) | Read: Read the Status Register Write: Write to the Status Register (note that not all bits are writable) |
BASE+2 (0x0E) | Read: No effect (junk value is returned) Write: Send Immediate – any data queued in the transmit FIFO is sent over the USB at the earliest opportunity. Without this the data will be queued until a timeout (~17ms) expires. Note that the value written to the register is ignored, any value written to the register will trigger the Send Immediate signal. |
BASE+3 (0x0F) | Read: No effect (junk value is returned) Write: No effect |
Bit (Value) | Meaning |
0 (0x01) | TX_FULL: read-only 0 if the transmit FIFO has space available, 1 if the transmit FIFO is full. Any writes to the FIFO will be ignored while the transmit FIFO is full. |
1 (0x02) | INT_ENABLE: read/write 0 if interrupts are disabled, 1 if interrupts are enabled. |
2 (0x04) | INT_TX: read/write 0 if interrupts will not be generated to report transmit FIFO state, 1 if an interrupt will be generated when the transmit FIFO has space available (providing INT_ENABLE is also set). |
3 (0x08) | INT_RX: read/write 0 if interrupts will not be generated to report receive FIFO state, 1 if an interrupt will be generated when the receive FIFO has space available (providing INT_ENABLE is also set). |
4 (0x10) | GPIO_IN: read/write Single bit GPIO, output from ECB, input to FT232H |
5 (0x20) | GPIO_OUT: read-only Single bit GPIO, output from FT232H, input to ECB |
6 (0x40) | IRQ: read-only 0 if no interrupt would be requested providing INT_ENABLE is also set, 1 if an interrupt would be requested providing INT_ENABLE is also set. |
7 (0x80) | RX_EMPTY: read-only 0 if the receive FIFO contains queued data, 1 if the receive FIFO is empty. Any reads from the FIFO while it is empty will return junk values. |
ECB Card Jumpers
Schematic
Component | Description | Example Part |
C1 | 47uF electrolytic capacitor, 0.2” lead spacing | Panasonic ECA-2AHG470 (Farnell order code 9694617) |
C2–C11 | 0.1uF multilayer ceramic capacitor, 0.2” lead spacing | Multicomp MCRR50104X7RK0050 (Farnell order code 1216440) |
C12 | No component (see Notes on Construction) | - |
RR1 | 22K bussed resistor network: 8 resistors, 9 pins | BOURNS 4609X-101-223LF (Farnell order code 9356924) |
R1, R2 | 2.2K ohm 0.25W (or 0.125W) resistor | Multicomp MF25 2K2 (Farnell order code 9341536) |
R3 | Wire jumper (see Notes on Construction) | Use excess lead cut off from a resistor |
J1 | 1×3 0.1“ header | TE Connectivity part 5-826629-0: 1×50 contact breakaway header strip (Farnell order code 3418388) |
J2 | 2×6 0.1” header | TE Connectivity part 5-826632-0: 2×50 contact breakaway header strip (Farnell order code 3418560) |
J3 | 2×10 0.1“ header | TE Connectivity part 5-826632-0: 2×50 contact breakaway header strip (Farnell order code 3418560) |
U1, U3 | 74LS244 | TI SN74LS244N (Farnell order code 1739688) |
U9 | 74AHCT244 (preferred) or 74LS244 | TI SN74AHCT244N (Farnell order code 1752769) |
U2 | 74LS245 | TI SN74LS245N (Farnell order code 1106085) |
U4 | 74LS688 | TI SN74LS688N (Farnell order code 1470949) |
U5 | 74LS38 | TI SN74LS38N (Farnell order code 1470758) |
U6 | 74AHCT139 (preferred) or 74LS139A | TI SN74AHCT139N (Farnell order code 1741539) |
U7, U11 | 74ACT32 (preferred), 74AHCT32 (untested but should work) or 74LS32 | TI SN74ACT32N (Farnell order code 1739969), TI SN74AHCT32N (Farnell order code 1749941) or TI SN74LS32N (Farnell order code 1740030) |
U8 | 74LS175 | TI SN74LS175N (Farnell order code 1607731) |
U10 | Adafruit FT232H Breakout (product 2264) | Mouser order code 485-2264, Digikey order code 1528-1449-ND |
U12 | DIN 41612 Connector, Type C Plug, 96 pin | TE Connectivity 5650913-5 (Farnell order code 1557020) |
(qty 5) | 20 pin DIP IC socket | Multicomp SPC15501 (Farnell order code 2678574) |
(qty 2) | 16 pin DIP IC socket | TE Connectivity 1-2199298-4 (Farnell order code 2445622) |
(qty 3) | 14 pin DIP IC socket | TE Connectivity 1-2199298-3 (Farnell order code 2445621) |
It is possible to build this board with entirely 74LS series logic, and this works well. However slightly higher performance can be achieved by substituting 74AHCT parts for U6 and U9, and 74ACT for U7 and U11. Testing on a Mark IV SBC at 36.864MHz, a board using only 74LS parts requires 2 I/O wait states, whereas with the 74AHCT parts at U6 and U9 the board operates correctly with only 1 I/O wait state. U7 and U11 can use 74ACT32 which also gives a further timing improvement. The forum thread has more information on how the timing improves with CMOS parts. Note that U1, U2 and U3 should always use 74LS as the bus interface benefits from having hysteresis on the inputs to improve noise rejection; the 74LS244 and 74LS245 parts have Schmitt trigger inputs.
Photographs
Example Code
FIFO_BASE = 0x0C FIFO_DATA = (FIFO_BASE+0) FIFO_STATUS = (FIFO_BASE+1) FIFO_SEND_IMM = (FIFO_BASE+2) ; Receive a block of length DE bytes from the FIFO to memory starting at address HL fifo_receive: ; Enter with: ; HL = pointer to data buffer ; DE = number of bytes to transmit ld b, e ; setup loop counter dec de inc d ld c, #FIFO_DATA ; load port address waitrx: in a, (FIFO_STATUS) rla ; RX_EMPTY bit into carry flag jr c, waitrx ; loop until data ready ini ; read from port C, write to HL, HL++, B-- jr nz, waitrx ; INI sets Z flag to indicate new value of B dec d jr nz, waitrx ret ; Transmit a block of length DE bytes to the FIFO from memory starting at address HL fifo_transmit: ; Enter with: ; HL = pointer to data buffer ; DE = number of bytes to transmit ld b, e ; setup loop counter dec de inc d ld c, #FIFO_DATA ; load port address waittx: in a, (FIFO_STATUS) rra ; TX_FULL bit into carry flag jr c, waittx ; loop while tx fifo full outi ; read from HL, write to port C, HL++, B-- jr nz, waittx ; OUTI sets Z flag to indicate new value of B dec d jr nz, waittx ret ; Request transfer of transmitted data ASAP (without this it is delayed up to 17ms) fifo_flush: out (FIFO_SEND_IMM), a ; we can write any value to the register ret
I also have a file transfer application for CP/M, FIFOPIPE. Drop me an email (will /at/ sowerbutts.com) if you'd like to try it out.
Software support
RomWBW 2.9.2-pre.3 included driver support for the ecb-usb-fifo board and this can be enabled with the following assembly customizations.
UFENABLE .SET TRUE
Inclusion of the driver in RomWBW will result in the board appearing as a serial port.
RetroBrew HBIOS v2.9.2-pre.3, 2019-08-07 SBC Z80 @ 3.992MHz 0 MEM W/S, 1 I/O W/S, INT MODE 2 512KB ROM, 512KB RAM SPK: IO=0x70 AY: IO=0x9A UART0: IO=0x68 16550A MODE=38400,8,N,1 UART1: IO=0x80 16550A MODE=300,8,N,1 DSRTC: MODE=STD Thu 2019-08-08 17:42:23 CHARGE=ON MD: UNITS=2 ROMDISK=384KB RAMDISK=384KB FD: IO=0x36 UNITS=2 RF: IO=0xA0 DEVICES=1 WP=OFF PPIDE: IO=0x60 DEVICES=2 PPIDE0: LBA BLOCKS=0x003DFC20 SIZE=1983MB PPIDE1: NO MEDIA ... USB-FIFO: IO=0x0C Unit Device Type Capacity/Mode ---------- ---------- ---------------- -------------------- Disk 0 MD1: RAM Disk 384KB,LBA Disk 1 MD0: ROM Disk 384KB,LBA Disk 2 FD0: Floppy Disk 3.5",DS/HD,CHS Disk 3 FD1: Floppy Disk 3.5",DS/HD,CHS Disk 4 RF0: RAM Floppy 4MB,LBA Disk 5 PPIDE0: Hard Disk 1983MB,LBA Disk 6 PPIDE1: Hard Disk -- Char 0 UART0: RS-232 38400,8,N,1 Char 1 UART1: RS-232 300,8,N,1 ... Char 6 SIO0: RS-232 9600,8,N,1
CP/M has limited
