The FT232H has a separate FIFO (first-in-first-out queue) for the receive and transmit directions. Each FIFO is 1KB in size. Data is transferred to/from the FIFOs over the USB link in blocks of up to 512 bytes. A “send immediate” operation is supported which causes any queued data in the transmit FIFO to be sent over the USB link at the earliest opportunity, otherwise the FT232H may wait a short while to accumulate more data before performing a transfer over the USB link.
ECB I/O Registers
I/O addressRegister use
Write: No effect
Bit (Value)Meaning
0 (0x01)TX_FULL: read-only
0 if interrupts are disabled,
1 if interrupts are enabled.
2 (0x04)INT_TX: read/write
3 (0x08)INT_RX: read/write
4 (0x10)GPIO_IN: read/write
5 (0x20)GPIO_OUT: read-only
6 (0x40)IRQ: read-only
7 (0x80)RX_EMPTY: read-only
ECB Card Jumpers
U1, U374LS244TI SN74LS244N (Farnell order code 1739688)
U974AHCT244 (preferred) or 74LS244TI SN74AHCT244N (Farnell order code 1752769)
U674AHCT139 (preferred) or 74LS139ATI SN74AHCT139N (Farnell order code 1741539)
U7, U1174ACT32 (preferred), 74AHCT32 (untested but should work) or 74LS32TI SN74ACT32N (Farnell order code 1739969), TI SN74AHCT32N (Farnell order code 1749941) or TI SN74LS32N (Farnell order code 1740030)
It is possible to build this board with entirely 74LS series logic, and this works well. However slightly higher performance can be achieved by substituting 74AHCT parts for U6 and U9, and 74ACT for U7 and U11. Testing on a Mark IV SBC at 36.864MHz, a board using only 74LS parts requires 2 I/O wait states, whereas with the 74AHCT parts at U6 and U9 the board operates correctly with only 1 I/O wait state. U7 and U11 can use 74ACT32 which also gives a further timing improvement. The forum thread has more information on how the timing improves with CMOS parts. Note that U1, U2 and U3 should always use 74LS as the bus interface benefits from having hysteresis on the inputs to improve noise rejection; the 74LS244 and 74LS245 parts have Schmitt trigger inputs.
Example Code
FIFO_BASE       = 0x0C
        ; Enter with:
        dec de
        inc d
        in a, (FIFO_STATUS)
        dec d
        jr nz, waitrx
        ; Enter with:
        dec de
        inc d
        in a, (FIFO_STATUS)
        dec d
        jr nz, waittx
boards/ecb/usb-fifo/start.1490370289.txt.gz · Last modified: 2017/03/24 11:44 by will
