ECB I/O Registers
I/O addressRegister use
Write: No effect
Bit (Value)Meaning
0 (0x01)TX_FULL: read-only
0 if interrupts are disabled,
1 if interrupts are enabled.
2 (0x04)INT_TX: read/write
3 (0x08)INT_RX: read/write
4 (0x10)GPIO_IN: read/write
5 (0x20)GPIO_OUT: read-only
6 (0x40)IRQ: read-only
7 (0x80)RX_EMPTY: read-only
ECB Card Jumpers
U1, U374LS244TI SN74LS244N (Farnell order code 1739688)
U974AHCT244 (preferred) or 74LS244TI SN74AHCT244N (Farnell order code 1752769)
U674AHCT139 (preferred) or 74LS139ATI SN74AHCT139N (Farnell order code 1741539)
U7, U1174LS32TI SN74LS32N (Farnell order code 1740030)
It is possible to build this board with entirely 74LS series logic, and this works well. However slightly higher performance can be achieved by substituting 74AHCT parts for U6 and U9. Testing on a Mark IV SBC at 36.864MHz, a board using only 74LS parts requires 2 I/O wait states, whereas with the 74AHCT parts at U6 and U9 the board operates correctly with only 1 I/O wait state. Substituting other parts for 74AHCT or similar has not been tested but should be generally okay, however U1, U2 and U3 should use 74LS as the bus interface benefits from having hysteresis on the inputs; the 74LS244 and 74LS245 parts have Schmitt trigger inputs.
Example Code
FIFO_BASE       = 0x0C
        ; Enter with:
        dec de
        inc d
        in a, (FIFO_STATUS)
        dec d
        jr nz, waitrx
        ; Enter with:
        dec de
        inc d
        in a, (FIFO_STATUS)
        dec d
        jr nz, waittx
boards/ecb/usb-fifo/start.1490117202.txt.gz · Last modified: 2017/03/21 13:26 by will
