ECB USB FIFO
ECB I/O Registers
I/O addressRegister use
Write: No effect
Bit (Value)Meaning
0 (0x01)TX_FULL: read-only
0 if interrupts are disabled,
1 if interrupts are enabled.
2 (0x04)INT_TX: read/write
3 (0x08)INT_RX: read/write
4 (0x10)GPIO_IN: read/write
5 (0x20)GPIO_OUT: read-only
6 (0x40)IRQ: read-only
7 (0x80)RX_EMPTY: read-only
Interrupts: Interrupt requests are controlled in two stages. The first stage is controlled by the INT_TX and INT_RX bits in the Status Register. Setting these bits to 1 causes an interrupt to be requested when the transmit FIFO has space available (INT_TX), or the receive FIFO contains data (INT_RX). The IRQ bit in the Status Register will be 1 only when either of these bits is set and the corresponding condition arises. The second stage is the INT_ENABLE bit: When the INT_ENABLE bit in the Status Register is set, and the IRQ bit is 1, the bus interrupt line selected with jumper J3 will be asserted to alert the CPU.
ECB Card Jumpers
Schematic
U1, U3, U974LS244TI SN74LS244N (Farnell order code 1739688)
U674LS139ATI SN74LS139AN (Farnell order code 9592296)
U7, U1174LS32TI SN74LS32N (Farnell order code 1740030)
It is recommended to use 74LS series parts on this board, at the time of writing it has not been tested with substitutions from other 74 series logic families. In particular U1, U2 and U3 benefit from having hysteresis (Schmitt triggers) on the inputs, which the 74LS244 and 74LS245 parts have.
Photographs
Example Code
FIFO_BASE       = 0x0C
FIFO_DATA       = (FIFO_BASE+0)
FIFO_STATUS     = (FIFO_BASE+1)
FIFO_SEND_IMM   = (FIFO_BASE+2)
fifo_receive:
        ; Enter with:
        dec de
        inc d
waitrx:
        in a, (FIFO_STATUS)
        dec d
        jr nz, waitrx
        ret
fifo_transmit:
        ; Enter with:
        dec de
        inc d
waittx:
        in a, (FIFO_STATUS)
        dec d
        jr nz, waittx
        ret
fifo_flush:
        ret
boards/ecb/usb-fifo/start.1490112278.txt.gz · Last modified: 2017/03/21 12:04 by will
