ECB USB FIFO
ECB I/O Registers
I/O address | Register use |
BASE+0 (0x0C) | Read: Remove one byte of data from the receive FIFO Write: Insert one byte of data into the transmit FIFO |
BASE+1 (0x0D) | Read: Read the Status Register Write: Write to the Status Register (note that not all bits are writable) |
BASE+2 (0x0E) | Read: No effect (junk value is returned) Write: Send Immediate – any data queued in the transmit FIFO is sent over the USB at the earliest opportunity. Without this the data will be queued until a timeout (~17ms) expires. Note that the value written to the register is ignored, any value written to the register will trigger the Send Immediate signal. |
BASE+3 (0x0F) | Read: No effect (junk value is returned) Write: No effect |
Bit (Value) | Meaning |
0 (0x01) | TX_FULL: read-only 0 if the transmit FIFO has space available, 1 if the transmit FIFO is full. Any writes to the FIFO will be ignored while the transmit FIFO is full. |
1 (0x02) | INT_ENABLE: read/write 0 if interrupts are disabled, 1 if interrupts are enabled. |
2 (0x04) | INT_TX: read/write 0 if interrupts will not be generated to report transmit FIFO state, 1 if an interrupt will be generated when the transmit FIFO has space available (providing INT_ENABLE is also set). |
3 (0x08) | INT_RX: read/write 0 if interrupts will not be generated to report receive FIFO state, 1 if an interrupt will be generated when the receive FIFO has space available (providing INT_ENABLE is also set). |
4 (0x10) | GPIO_IN: read/write Single bit GPIO, output from ECB, input to FT232H |
5 (0x20) | GPIO_OUT: read-only Single bit GPIO, output from FT232H, input to ECB |
6 (0x40) | IRQ: read-only 0 if no interrupt would be requested providing INT_ENABLE is also set, 1 if an interrupt would be requested providing INT_ENABLE is also set. |
7 (0x80) | RX_EMPTY: read-only 0 if the receive FIFO contains queued data, 1 if the receive FIFO is empty. Any reads from the FIFO while it is empty will return junk values. |
Interrupts: Interrupt requests are controlled in two stages. The first stage is controlled by the INT_TX and INT_RX bits in the Status Register. Setting these bits to 1 will cause an interrupt to be requested when the transmit FIFO has space available (INT_TX), or the receive FIFO contains data (INT_RX). The IRQ bit in the Status Register will be 1 when either of these bits is set and the corresponding condition arises. The second stage is the INT_ENABLE bit: When the INT_ENABLE bit in the Status Register is set, and the IRQ bit is 1, the bus interrupt line selected with jumper J3 will be asserted to alert the CPU.
ECB Card Jumpers
Schematic
Component | Description | Example Part |
C1 | 47uF electrolytic capacitor, 0.2” lead spacing | Panasonic ECA-2AHG470 (Farnell order code 9694617) |
C2–C11 | 0.1uF multilayer ceramic capacitor, 0.2” lead spacing | Multicomp MCRR50104X7RK0050 (Farnell order code 1216440) |
C12 | No component (see Notes on Construction) | - |
RR1 | 22K bussed resistor network: 8 resistors, 9 pins | BOURNS 4609X-101-223LF (Farnell order code 9356924) |
R1, R2 | 2.2K ohm 0.25W (or 0.125W) resistor | Multicomp MF25 2K2 (Farnell order code 9341536) |
R3 | Wire jumper (see Notes on Construction) | Use excess lead cut off from a resistor |
J1 | 1×3 0.1“ header | TE Connectivity part 5-826629-0: 1×50 contact breakaway header strip (Farnell order code 3418388) |
J2 | 2×6 0.1” header | TE Connectivity part 5-826632-0: 2×50 contact breakaway header strip (Farnell order code 3418560) |
J3 | 2×10 0.1“ header | TE Connectivity part 5-826632-0: 2×50 contact breakaway header strip (Farnell order code 3418560) |
U1, U3, U9 | 74LS244 | TI SN74LS244N (Farnell order code 1739688) |
U2 | 74LS245 | TI SN74LS245N (Farnell order code 1106085) |
U4 | 74LS688 | TI SN74LS688N (Farnell order code 1470949) |
U5 | 74LS38 | TI SN74LS38N (Farnell order code 1470758) |
U6 | 74LS139A | TI SN74LS139AN (Farnell order code 9592296) |
U7, U11 | 74LS32 | TI SN74LS32N (Farnell order code 1740030) |
U8 | 74LS175 | TI SN74LS175N (Farnell order code 1607731) |
U10 | Adafruit FT232H Breakout (product 2264) | Mouser order code 485-2264, Digikey order code 1528-1449-ND |
U12 | DIN 41612 Connector, Type C Plug, 96 pin | TE Connectivity 5650913-5 (Farnell order code 1557020) |
(qty 5) | 20 pin DIP IC socket | Multicomp SPC15501 (Farnell order code 2678574) |
(qty 2) | 16 pin DIP IC socket | TE Connectivity 1-2199298-4 (Farnell order code 2445622) |
(qty 3) | 14 pin DIP IC socket | TE Connectivity 1-2199298-3 (Farnell order code 2445621) |
It is recommended to use 74LS series parts on this board, at the time of writing it has not been tested with substitutions from other 74 series logic families. In particular U1, U2 and U3 benefit from having hysteresis (Schmitt triggers) on the inputs, which the 74LS244 and 74LS245 parts have.
Photographs
Example Code
FIFO_BASE = 0x0C FIFO_DATA = (FIFO_BASE+0) FIFO_STATUS = (FIFO_BASE+1) FIFO_SEND_IMM = (FIFO_BASE+2) ; Receive a block of length DE bytes from the FIFO to memory starting at address HL fifo_receive: ; Enter with: ; HL = pointer to data buffer ; DE = number of bytes to transmit ld b, e ; setup loop counter dec de inc d ld c, #FIFO_DATA ; load port address waitrx: in a, (FIFO_STATUS) rla ; RX_EMPTY bit into carry flag jr c, waitrx ; loop until data ready ini ; read from port C, write to HL, HL++, B-- jr nz, waitrx ; INI sets Z flag to indicate new value of B dec d jr nz, waitrx ret ; Transmit a block of length DE bytes to the FIFO from memory starting at address HL fifo_transmit: ; Enter with: ; HL = pointer to data buffer ; DE = number of bytes to transmit ld b, e ; setup loop counter dec de inc d ld c, #FIFO_DATA ; load port address waittx: in a, (FIFO_STATUS) rra ; TX_FULL bit into carry flag jr c, waittx ; loop while tx fifo full outi ; read from HL, write to port C, HL++, B-- jr nz, waittx ; OUTI sets Z flag to indicate new value of B dec d jr nz, waittx ret ; Request transfer of transmitted data ASAP (without this it is delayed up to 17ms) fifo_flush: out (FIFO_SEND_IMM), a ; we can write any value to the register ret
