ECB I/O Registers
I/O addressRegister use
Write: No effect
Bit (Value)Meaning
0 (0x01)TX_FULL: read-only
0 if interrupts are disabled,
1 if interrupts are enabled.
2 (0x04)INT_TX: read/write
3 (0x08)INT_RX: read/write
4 (0x10)GPIO_IN: read/write
5 (0x20)GPIO_OUT: read-only
6 (0x40)IRQ: read-only
7 (0x80)RX_EMPTY: read-only
The INT_TX and INT_RX bits in the Status Register control the conditions under which an interrupt will be requested. The IRQ bit always reflects if either condition is met regardless of the value of INT_ENABLE. The bus interrupt line will be asserted only when the INT_ENABLE bit is also set. In other words, the bus interrupt line is asserted only when INT_TX and/or INT_RX are set, one or both of the relevant conditions is met, and INT_ENABLE is also set. So, for example, software which wants to receive an interrupt when data arrives in the receive FIFO over USB should set both INT_RX and INT_ENABLE. If the interrupt line is shared with multiple devices the interrupt service routine can then check the IRQ bit to determine if the USB-FIFO card is requesting the interrupt before calling the USB-FIFO interrupt handler code.
When the USB cable is disconnected, TX_FULL =1 and RX_EMPTY =1 indicating (correctly!) that data cannot be transferred in either direction.
ECB Card Jumpers
U1, U3, U974LS244TI SN74LS244N (Farnell order code 1739688)
U674LS139ATI SN74LS139AN (Farnell order code 9592296)
U7, U1174LS32TI SN74LS32N (Farnell order code 1740030)
It is recommended to use 74LS series parts on this board, at the time of writing it has not been tested with substitutions from other 74 series logic families. In particular U1, U2 and U3 benefit from having hysteresis (Schmitt triggers) on the inputs, which the 74LS244 and 74LS245 parts have.
Example Code
FIFO_BASE       = 0x0C
        ; Enter with:
        dec de
        inc d
        in a, (FIFO_STATUS)
        dec d
        jr nz, waitrx
        ; Enter with:
        dec de
        inc d
        in a, (FIFO_STATUS)
        dec d
        jr nz, waittx
boards/ecb/usb-fifo/start.1489998964.txt.gz · Last modified: 2017/03/20 04:36 by will
