ECB USB FIFO
ECB I/O Registers
I/O addressRegister use
Write: No effect
Bit (Value)Meaning
0 (0x01)TX_FULL: read-only
0 when the transmit FIFO has space available,
1 when the transmit FIFO is full.
0 if interrupts are disabled,
1 if interrupts are enabled.
2 (0x04)INT_TX: read/write
3 (0x08)INT_RX: read/write
4 (0x10)GPIO_IN: read/write
Data from ECB to FT232H
5 (0x20)GPIO_OUT: read-only
Data from FT232H to ECB
6 (0x40)IRQ: read-only
7 (0x80)RX_EMPTY: read-only
0 when the receive FIFO contains queued data,
1 when the receive FIFO is empty.
The INT_TX and INT_RX bits in the Status Register control the conditions under which an interrupt will be requested. The IRQ bit always reflects if either condition is met regardless of the value of INT_ENABLE. The bus interrupt line will be asserted only when the INT_ENABLE bit is also set. In other words, the bus interrupt line is asserted only when INT_TX and/or INT_RX are set, one or both of the relevant conditions is met, and INT_ENABLE is also set. So, for example, software which wants to receive an interrupt when data arrives in the receive FIFO over USB should set both INT_RX and INT_ENABLE. If the interrupt line is shared with multiple devices the interrupt service routine can then check the IRQ bit to determine if the USB-FIFO card is requesting the interrupt before calling the USB-FIFO interrupt handler code.
When the USB cable is disconnected, TX_FULL =1 and RX_EMPTY =1 indicating (correctly!) that data cannot be transferred in either direction.
ECB Card Jumpers
Schematic
U1, U3, U974LS244TI SN74LS244N (Farnell order code 1739688)
U674LS139ATI SN74LS139AN (Farnell order code 9592296)
U7, U1174LS32TI SN74LS32N (Farnell order code 1740030)
The FT232H write signal is active on the falling edge of the signal, instead of the standard rising edge. To ensure the data signals are steady for long enough to meet its setup time requirements, the write signal is delayed by routing it through a few gates in U3 and U7. R3 and C12 can form an LC circuit used to extend this delay if required. Alternatively the delay can be shortened by omitting the wire jumper at R3 and connecting U3 pin 17 to U3 pins 5, 7 or 13. Testing indicates that the standard delay should suit all current Retrobrew Computers systems and so the LC circuit components should not be required.
For Linux I have written a short C program which uses libftdi1 to program the EEPROM. The tarball contains both the source code and a binary with libftdi1 statically linked in. Ensure the FT232H board is the only connected FTDI device (just in case it tries to overwrite the EEPROM in other devices!) and then run “sudo ./program-eeprom -w” to program the device. Running “sudo ./program-eeprom” (without the “-w” option) will report the current EEPROM contents.
For MacOS I had success running FT_PROG in a virtual Windows machine (using Parallels Desktop) using the USB passthrough feature.
It is recommended to use 74LS series parts on this board, at the time of writing it has not been tested with substitutions from other 74 series logic families. In particular U1, U2 and U3 benefit from having hysteresis (Schmitt triggers) on the inputs, which the 74LS244 and 74LS245 parts have.
Photographs
Example Code
FIFO_BASE       = 0x0C
FIFO_DATA       = (FIFO_BASE+0)
FIFO_STATUS     = (FIFO_BASE+1)
FIFO_SEND_IMM   = (FIFO_BASE+2)
fifo_receive:
        ; Enter with:
        dec de
        inc d
waitrx:
        in a, (FIFO_STATUS)
        dec d
        jr nz, waitrx
        ret
fifo_transmit:
        ; Enter with:
        dec de
        inc d
waittx:
        in a, (FIFO_STATUS)
        dec d
        jr nz, waittx
        ret
fifo_flush:
        ret
boards/ecb/usb-fifo/start.1489970558.txt.gz · Last modified: 2017/03/19 20:42 by will
