EuroCard Bus Boards
ECB Backplanes
Board Name | Description/Features |
ECB Mini Backplane | A 3-slot EuroCard Bus Backplane |
Backplane-8 | An 8-slot EuroCard Bus Backplane |
Extended Backplane-12 | A 12-slot EuroCard Bus Backplane |
12-Slot Backplane for Siemens 505-6508 | A 12-slot EuroCard Bus Backplane with a form factor specifically designed to fit in a readily available Siemens 505-6508 chassis box |
ECB Processor Boards
KISS-68030 | A Motorola 68030 processor board. Requires the Multifunction Controller (MF/PIC) board for I/O (see below). DRAM memory up to 256Mb. Linux runs in 32Mb. |
Mini-M68K | A Motorola 68008 processor board. Requires the Multifunction Controller (MF/PIC) board for I/O (see below). Runs CP/M-68. |
SBC-188 | An Intel/AMD 80C188 processor board. Capable of functioning both as an an SBC and on the ECB bus. |
Mark IV | A Zilog Z180 processor board. Capable of functioning both as an an SBC and on the ECB bus. SDcard & IDE-8 (for CF card) interfaces on-board. |
SBC V2 | A Zilog Z80 processor board. Capable of functioning both as an an SBC and on the ECB bus. |
6x0x-ATX-6U | An MOS 6502 / Motorola 6809 processor board. Electrically capable of functioning both as an an SBC and on the ECB bus, but ECB software support currently limited |
N8 | A Zilog Z180 processor board. Electrically capable of functioning both as an an SBC and on the ECB bus, but ECB software support currently limited |
ECB Input/Output/Memory Cards
PropIO | A Propeller-based I/O board that provides keyboard, video, and SD Card storage. |
4PIO | The ECB-4PIO board contains 4 Z80A-PIO and the complete Bus-Control-Logic for the ECB-Systembus conform to KONTRON |
ModPrn | ECB-PCB to communicate with SBC V1, SBC V2 or any other developed Z80-CPU to outside the Computer system (Serial communication, Communication via Modem) or to use serial Printers with RS232/V.24-Interface |
RamFloppy | A RAM Floppy does not use the local memory resources of the processor, but instead is implemented as an external storage subsystem, which may functionally appear as being similar to a floppy or modest hard drive. |
Color VDU | A traditional video display board with color capability. Provides 80×25 text and will drive VGA displays that are capable of EGA display frequencies. Also includes a keyboard and mouse interface. |
VDU | |
VGA3 | 80×25 or 80×30 text display; operates at VGA frequencies to operate on a greater number of displays than the CVDU (above). Fonts are programmable. Includes an IBM PS/2 keyboard interface. Operates memory-mapped (for SBC-188 MSDOS), or registered access (similar to CVDU). |
Dual SD Card | A board providing Dual SD Card storage |
DiskIO V3 | A board providing floppy and IDE storage support |
MF/PIC | Multifunction Programmable Interrupt Controller support board required by the ECB Mini-68K CPU and ECB KISS-68030 CPU boards. It may also be used with the SBC v2 (Z80) to provide mode 2 interrupt vectoring. |
4MEM | 4MB expanded memory board for SBC-188. Uses EMM4MEM.sys driver. Also expands SBC-188 memory to full 640K. Expanded memory is good for a battery-backed Ramdisk. |
4UART | Quad high-speed UART interfaces to RS-232 or USB at up to 3Mbps. 2 ports are dedicated to USB; 2 ports are USB or RS-232, selectable. |
ADIO | An Analog/Digital I/O Board |
DSKY | A Display Keyboard unit providing a hexidecimal display and numeric input keypad. |
Cassette Interface | Allows for storage/retrial of files on cassette tapes using the Kansas City Standard |
USB FIFO | A EuroCard Bus board providing a fast interface between ECB machines and modern PCs over USB. |
SCG | The “Sprite Color Graphics” is an ECB video display board based on the TMS9918 which features color graphics and sprite management. Board also includes AY-3-8910 sound support and dual joystick support. |
ECB Accessory Cards
Bus Monitor | Card with “blinkenlights” for monitoring the ECB bus and single-stepping the CPU. |
Bus Extender | Extension card which allows for ECB cards to be height-extended out of the chassis for easier debugging. |
Prototyper C'T Projekt | ECB bus prototyping card from C'T Projekt article. |
Prototype w/I/O Decode | ECB bus prototyping card with I/O Decode. |
"Orphaned" ECB Cards
These are ECB cards which:
- Have no KiCAD or Gerber files available on the wiki
- Have no community member listed as a board distributor on the RetroBrew Computers Board Inventory page
Active Termination | A board which provides Active Termination to the ECB bus |
Retired ECB Cards
ECB Accessory Cards
VDU | https://retrobrewcomputers.org/n8vem-pbwiki-archive/0/35845334/48860720/4200893/index.htm |
Retired ECB Cards
ECB Board I/O Port Guidelines
Board | Ports | Fixed Port | |
4MEM boards x 4 | 00..07 | ||
Duel SD card | 08..09 | ||
ECB USB FIFO | 0C..0F | ||
IDE & Floppy Controllers (DISK I/O, Duel IDE) | 20..3F | ||
ECB 4PIO | 20..2F | N | |
Z180 Mark IV internal registers | 40..7F | ||
N8 Home Computer internal registers | 40..7F | ||
MF/PIC | 40..4F | Has also been at 80..8F | |
SBC v1/v2 on-board peripherals | 60..7F | Y | |
Z180 Mark IV on board peripherals | 80..8F | ||
N8 Home Computer on board peripherals | 80..9F | ||
SCG graphics (including AY-3-8910 sound) | 98..9F | N | Same as N8 |
RAM-Floppy x 2 | A0..A7 | N | Board 1 A0-A3 Board 2 A4-A7 |
Zilog peripherals | B0..BF | N | |
Prop I/O | A8..AF | ||
4UART | C0..DF | N | |
CVDU | E0..EF | ||
VGA3 | E0..E7 | ||
Reserved | F0..FF | For experimental boards | |
VDU (wired port) | F0..F3 |
