EuroCard Bus Boards
ECB Backplanes
ECB Processor Boards
ECB Backplanes
ECB Input/Output/Memory Cards
VDU
ECB Accessory Cards
"Orphaned" ECB Cards
These are ECB cards which:
Retired ECB Cards
ECB Accessory Cards
VDU https://retrobrewcomputers.org/n8vem-pbwiki-archive/0/35845334/48860720/4200893/index.htm
Retired ECB Cards
ECB Board I/O Port Guidelines
BoardPortsFixed Port
4MEM boards x 400..07
Duel SD card08..09
ECB USB FIFO0C..0F
ECB 4PIO20..2FN
SBC v1/v2 on-board peripherals60..7FY
SCG graphics (including AY-3-8910 sound)98..9FNSame as N8
RAM-Floppy x 2A0..A7NBoard 1 A0-A3 Board 2 A4-A7
Zilog peripheralsB0..BFN
Prop I/OA8..AF
4UARTC0..DFN
CVDUE0..EF
VGA3E0..E7
VDU (wired port)F0..F3
boards/ecb/start.1546084020.txt.gz · Last modified: 2018/12/29 06:47 by b1ackmai1er
