EuroCard Bus Boards
ECB Backplanes
ECB Processor Boards
ECB Input/Output/Memory Cards
ECB Accessory Cards
"Orphaned" ECB Cards
These are ECB cards which:
Retired ECB Cards
ECB Board I/O Port Guidelines
00..07 4 x 4MEM boards
08..09 Dual SD card
0C..0F ECB USB FIFO
60..7F SBC v1/v2 on-board I/O
98..9F SCG graphics (same as N8)
A0..A7 2 x RAM-Floppy cards
A8..AF PropI/O
C0..DF 4UART
E0..EF CVDU
E0..E7 VGA3
F0..F3 VDU (wired port)
Downloadable: Board_Ports.pdf
boards/ecb/start.1507320915.txt.gz · Last modified: 2017/10/06 16:15 by jcoffman
