EuroCard Bus Boards
ECB Backplanes
ECB Processor Boards
ECB TRAM Carrier An INMOS Transputer TRAM Carrier board that supports up to 4 INMOS TRAM's. This board requires the ECB INMOS Link board to be useful and has NO connection to the ECB Bus except for power. Can connecto to other INMOS Link boards if required.
ECB Input/Output/Memory Cards
ECB Accessory Cards
"Orphaned" ECB Cards
These are ECB cards which:
Retired ECB Cards
ECB Board I/O Port Guidelines
00..07 4 x 4MEM boards
08..09 Dual SD card
0C..0F ECB USB FIFO
60..7F SBC v1/v2 on-board I/O
A0..A7 2 x RAM-Floppy cards
A8..AF PropI/O
E0..EF VDU & CVDU
Downloadable: Board_Ports.pdf
boards/ecb/start.1499310738.txt.gz · Last modified: 2017/07/05 23:12 by trick-1
