EuroCard Bus Boards
ECB Backplanes
ECB Processor Boards
ECB Input/Output/Memory Cards
ECB Accessory Cards
"Orphaned" ECB Cards
These are ECB cards which:
Retired ECB Cards
ECB Board I/O Port Guidelines
00..07 4 x 4MEM boards
08..09 Dual SD card
60..7F SBC v1/v2 on-board I/O
A0..A7 2 x RAM-Floppy cards
A8..AF PropI/O
E0..EF VDU & CVDU
Downloadable: Board_Ports.pdf
boards/ecb/start.1460828911.txt.gz · Last modified: 2016/04/16 13:48 by admin
