Next revision Both sides next revision
boards:ecb:start [2017/10/06 16:12]
jcoffman [ECB Input/Output/Memory Cards]
boards:ecb:start [2018/09/01 09:35]
b1ackmai1er [ECB Board I/O Port Guidelines]
Line 17: Line 17:
 ^Board Name  ^Description/​Features ​ | ^Board Name  ^Description/​Features ​ |
-|[[:​boards:​ecb:​kiss-68030:​start|KISS-68030]] ​ |A Motorola 68030 processor board. Requires the Multifunction Controller (MF/PIC) board for I/O (see below). ​This is a new board under active development as of late 2015.  | +|[[:​boards:​ecb:​kiss-68030:​start|KISS-68030]] ​ |A Motorola 68030 processor board. Requires the Multifunction Controller (MF/PIC) board for I/O (see below). ​DRAM memory up to 256Mb. Linux runs in 32Mb.  |
-|[[:​boards:​ecb:​mini-68k:​start|MINI-68K]]  |A Motorola 68008 processor board. Requires the Multifunction Controller (MF/PIC) board for I/O (see below). ​ |+|[[:​boards:​ecb:​mini-68k:​start|Mini-M68K]]  |A Motorola 68008 processor board. Requires the Multifunction Controller (MF/PIC) board for I/O (see below). Runs CP/M-68.  |
 |[[:​boards:​sbc:​sbc-188:​start|SBC-188]] ​ |An Intel/AMD 80C188 processor board. //Capable of functioning both as an an SBC and on the ECB bus.// ​  | |[[:​boards:​sbc:​sbc-188:​start|SBC-188]] ​ |An Intel/AMD 80C188 processor board. //Capable of functioning both as an an SBC and on the ECB bus.// ​  |
-|[[:​boards:​sbc:​z180_mark_iv:​z180_mark_iv|Mark IV]]  |A Zilog Z180 processor board. Capable of functioning both as an an SBC and on the ECB bus.  |+|[[:​boards:​sbc:​z180_mark_iv:​z180_mark_iv|Mark IV]]  |A Zilog Z180 processor board. Capable of functioning both as an an SBC and on the ECB bus. SDcard & IDE-8 (for CF card) interfaces on-board.  |
 |[[:​boards:​sbc:​sbc_v2:​start|SBC V2]]  |A Zilog Z80 processor board. //Capable of functioning both as an an SBC and on the ECB bus.// ​  | |[[:​boards:​sbc:​sbc_v2:​start|SBC V2]]  |A Zilog Z80 processor board. //Capable of functioning both as an an SBC and on the ECB bus.// ​  |
 |[[:​boards:​sbc:​6x0x-atx-6u:​start|6x0x-ATX-6U]] ​ |An MOS 6502 / Motorola 6809 processor board. //​Electrically capable of functioning both as an an SBC and on the ECB bus, but ECB software support currently limited// ​  | |[[:​boards:​sbc:​6x0x-atx-6u:​start|6x0x-ATX-6U]] ​ |An MOS 6502 / Motorola 6809 processor board. //​Electrically capable of functioning both as an an SBC and on the ECB bus, but ECB software support currently limited// ​  |
-|[[:​boards:​sbc:​n8:​start|N8]]  |A Zilog Z180 processor board. //​Electrically capable of functioning both as an an SBC and on the ECB bus, but ECB software support currently limited// ​  |+|[[:​boards:​sbc:​n8:​n8|N8]]  |A Zilog Z180 processor board. //​Electrically capable of functioning both as an an SBC and on the ECB bus, but ECB software support currently limited// ​  |
Line 41: Line 41:
 |[[:​boards:​ecb:​diskio-v3:​start|DiskIO V3]]  |A board providing floppy and IDE storage support ​ | |[[:​boards:​ecb:​diskio-v3:​start|DiskIO V3]]  |A board providing floppy and IDE storage support ​ |
 |[[:​boards:​ecb:​mf-pic:​start|MF/​PIC]] ​ |Multifunction Programmable Interrupt Controller support board required by the ECB Mini-68K CPU and ECB KISS-68030 CPU boards. It may also be used with the SBC v2 (Z80) to provide mode 2 interrupt vectoring. ​ | |[[:​boards:​ecb:​mf-pic:​start|MF/​PIC]] ​ |Multifunction Programmable Interrupt Controller support board required by the ECB Mini-68K CPU and ECB KISS-68030 CPU boards. It may also be used with the SBC v2 (Z80) to provide mode 2 interrupt vectoring. ​ |
-|[[:​boards:​ecb:​adio:​start|4MEM]]  |4MB expanded memory board for SBC-188. Uses EMM4MEM.sys driver. Also expands SBC-188 memory to full 640K. Expanded memory is good for a battery-backed Ramdisk. ​ | +|4MEM  |4MB expanded memory board for SBC-188. Uses EMM4MEM.sys driver. Also expands SBC-188 memory to full 640K. Expanded memory is good for a battery-backed Ramdisk. ​ |
-|[[:​boards:​ecb:​adio:​start|4UART]] ​ |Quad high-speed UART interfaces to RS-232 or USB at up to 3Mbps. ​ 2 ports are dedicated to USB; 2 ports are USB or RS-232, selectable. ​ |+|[[:​boards:​ecb:​adio:​start|4UART]] ​ |Quad high-speed UART interfaces to RS-232 or USB at up to 3Mbps. 2 ports are dedicated to USB; 2 ports are USB or RS-232, selectable. ​ |
 |[[:​boards:​ecb:​adio:​start|ADIO]] ​ |An Analog/​Digital I/O Board  | |[[:​boards:​ecb:​adio:​start|ADIO]] ​ |An Analog/​Digital I/O Board  |
 |[[:​boards:​ecb:​dsky:​start|DSKY]] ​ |A Display Keyboard unit providing a hexidecimal display and numeric input keypad. ​ | |[[:​boards:​ecb:​dsky:​start|DSKY]] ​ |A Display Keyboard unit providing a hexidecimal display and numeric input keypad. ​ |
Line 61: Line 61:
 ===== "​Orphaned"​ ECB Cards ===== ===== "​Orphaned"​ ECB Cards =====
 These are ECB cards which: These are ECB cards which:
   - Have no KiCAD or Gerber files available on the wiki   - Have no KiCAD or Gerber files available on the wiki
   - Have no community member listed as a board distributor on the [[:​boardinventory|RetroBrew Computers Board Inventory]] page   - Have no community member listed as a board distributor on the [[:​boardinventory|RetroBrew Computers Board Inventory]] page
 These board could be "​brought back" if KiCAD/​Gerber files are located, or if someone is willing to re-enter the schematic into KiCAD and re-route a new board. These board could be "​brought back" if KiCAD/​Gerber files are located, or if someone is willing to re-enter the schematic into KiCAD and re-route a new board.
 |[[:​boards:​ecb:​orphaned:​active-termination:​start|Active Termination]] ​ |A board which provides Active Termination to the ECB bus  | |[[:​boards:​ecb:​orphaned:​active-termination:​start|Active Termination]] ​ |A board which provides Active Termination to the ECB bus  |
 +|VDU  |https://​retrobrewcomputers.org/​n8vem-pbwiki-archive/​0/​35845334/​48860720/​4200893/​index.htm ​ |
 ===== Retired ECB Cards ===== ===== Retired ECB Cards =====
Line 75: Line 82:
 ===== ECB Board I/O Port Guidelines ===== ===== ECB Board I/O Port Guidelines =====
-<code> +^Board^Ports^Fixed Port^ |
-00..07 ​4 x 4MEM boards +^<font inherit/​Courier New,​Courier,​monospace;;​inherit;;​inherit>​4MEM boards x 4</​font>​|<​font inherit/​Courier New,​Courier,​monospace;;​inherit;;​inherit>00..07</​font>​| | |
-08..09 ​Dual SD card +^<font inherit/​Courier New,​Courier,​monospace;;​inherit;;​inherit>​Duel SD card</​font>​|<​font inherit/​Courier New,​Courier,​monospace;;​inherit;;​inherit>​08..09</​font>​| | |
-0C..0F ​ECB USB FIFO +^<font inherit/​Courier New,​Courier,​monospace;;​inherit;;​inherit>​ECB USB FIFO</​font>​|<​font inherit/​Courier New,​Courier,​monospace;;​inherit;;​inherit>​0C..0F</​font>​| | |
-20..3F IDE & Floppy ​controllers ​(DiskI/O, Dual IDE) +^<font inherit/​Courier New,​Courier,​monospace;;​inherit;;​inherit>​IDE & Floppy ​Controllers ​(DISK I/O, Duel IDE)</​font>​|<​font inherit/​Courier New,​Courier,​monospace;;​inherit;;​inherit>​20..3F</​font>​| | |
-40..7F Z180 Mark IV internal registers +^<font inherit/​Courier New,​Courier,​monospace;;​inherit;;​inherit>​ECB 4PIO</​font>​|<​font inherit/​Courier New,​Courier,​monospace;;​inherit;;​inherit>​20..2F</​font>​| | |
-40..7F N8 Home Computer internal registers +^<font inherit/​Courier New,​Courier,​monospace;;​inherit;;​inherit>​Z180 Mark IV internal registers</​font>​|<​font inherit/​Courier New,​Courier,​monospace;;​inherit;;​inherit>​40..7F</​font>​| | |
-40..4F MF/​PIC ​– has also been at 80..8F +^<font inherit/​Courier New,​Courier,​monospace;;​inherit;;​inherit>​N8 Home Computer internal registers</​font>​|<​font inherit/​Courier New,​Courier,​monospace;;​inherit;;​inherit>​40..7F</​font>​| | |
-60..7F ​SBC v1/v2 on-board ​I/+^<font inherit/​Courier New,​Courier,​monospace;;​inherit;;​inherit>​MF/PIC</​font>​|<​font inherit/​Courier New,​Courier,​monospace;;​inherit;;​inherit>​40..4F</​font>​| |<font inherit/​Courier New,​Courier,​monospace;;​inherit;;​inherit>​Has ​also been at 80..8F</​font>​|
-80..8F Z180 Mark IV on-board peripherals +^<font inherit/​Courier New,​Courier,​monospace;;​inherit;;​inherit>​SBC v1/v2 on-board ​peripherals<​/font>​|<​font inherit/​Courier New,​Courier,​monospace;;​inherit;;​inherit>​60..7F</​font>​|<​font inherit/​Courier New,​Courier,​monospace;;​inherit;;​inherit>​Y</​font>​| |
-80..9F N8 Home Computer on-board peripherals +^<font inherit/​Courier New,​Courier,​monospace;;​inherit;;​inherit>​Z180 Mark IV on board peripherals</​font>​|<​font inherit/​Courier New,​Courier,​monospace;;​inherit;;​inherit>​80..8F</​font>​| | |
-98..9F SCG graphics (same as N8) +^<font inherit/​Courier New,​Courier,​monospace;;​inherit;;​inherit>​N8 Home Computer on board peripherals</​font>​|<​font inherit/​Courier New,​Courier,​monospace;;​inherit;;​inherit>​80..9F</​font>​| | |
-A0..A7 ​2 x RAM-Floppy cards +^<font inherit/​Courier New,​Courier,​monospace;;​inherit;;​inherit>​SCG graphics (including AY-3-8910 sound)</​font>​|<​font inherit/​Courier New,​Courier,​monospace;;​inherit;;​inherit>​98..9F</​font>​| |<font inherit/​Courier New,​Courier,​monospace;;​inherit;;​inherit>​Same ​as N8</​font>​|
-A8..AF ​PropI/O +^<font inherit/​Courier New,​Courier,​monospace;;​inherit;;​inherit>​RAM-Floppy x 2</​font>​|<​font inherit/​Courier New,​Courier,​monospace;;​inherit;;​inherit>​A0..A7</​font>​| | |
-C0..DF ​4UART +^<font inherit/​Courier New,​Courier,​monospace;;​inherit;;​inherit>​Zilog peripherals</​font>​|<​font inherit/​Courier New,​Courier,​monospace;;​inherit;;​inherit>​B0..BF</​font>​|<​font inherit/​Courier New,​Courier,​monospace;;​inherit;;​inherit>​N</​font>​| |
-E0..EF ​CVDU +^<font inherit/​Courier New,​Courier,​monospace;;​inherit;;​inherit>​Prop I/​O</​font>​|<​font inherit/​Courier New,​Courier,​monospace;;​inherit;;​inherit>​A8..AF</font>| | |
-E0..E7 ​VGA3 +^<font inherit/​Courier New,​Courier,​monospace;;​inherit;;​inherit>​4UART</​font>​|<​font inherit/​Courier New,​Courier,​monospace;;​inherit;;​inherit>​C0..DF</​font>​| | |
-F0..FF ​reserved for experimental boards +^<font inherit/​Courier New,​Courier,​monospace;;​inherit;;​inherit>​CVDU</​font>​|<​font inherit/​Courier New,​Courier,​monospace;;​inherit;;​inherit>​E0..EF</​font>​| | |
-F0..F3 ​VDU (wired port) +^<font inherit/​Courier New,​Courier,​monospace;;​inherit;;​inherit>​VGA3</​font>​|<​font inherit/​Courier New,​Courier,​monospace;;​inherit;;​inherit>​E0..E7</​font>​| | |
-</code>+^<font inherit/​Courier New,​Courier,​monospace;;​inherit;;​inherit>​Reserved</​font>​|<​font inherit/​Courier New,​Courier,​monospace;;​inherit;;​inherit>​F0..FF</​font>​| |<font inherit/​Courier New,​Courier,​monospace;;​inherit;;​inherit>​For ​experimental boards</​font>​|
 +^<font inherit/​Courier New,​Courier,​monospace;;​inherit;;​inherit>​VDU (wired port)</font>​|<​font inherit/​Courier New,​Courier,​monospace;;​inherit;;​inherit>​F0..F3</​font>| | |
-Downloadable:​ {{:​boards:​ecb:​board_ports.pdf|Board_Ports.pdf}}+\\
boards/ecb/start.txt · Last modified: 2019/03/20 08:24 by b1ackmai1er
