Both sides next revision
boards:ecb:start [2017/10/06 16:04] jcoffman [ECB Input/Output/Memory Cards] |
boards:ecb:start [2018/07/09 08:56] b1ackmai1er [ECB Board I/O Port Guidelines] |
^Board Name ^Description/Features | | ^Board Name ^Description/Features | |
|[[:boards:ecb:kiss-68030:start|KISS-68030]] |A Motorola 68030 processor board. Requires the Multifunction Controller (MF/PIC) board for I/O (see below). This is a new board under active development as of late 2015. | | |[[:boards:ecb:kiss-68030:start|KISS-68030]] |A Motorola 68030 processor board. Requires the Multifunction Controller (MF/PIC) board for I/O (see below). DRAM memory up to 256Mb. Linux runs in 32Mb. | |
|[[:boards:ecb:mini-68k:start|MINI-68K]] |A Motorola 68008 processor board. Requires the Multifunction Controller (MF/PIC) board for I/O (see below). | | |[[:boards:ecb:mini-68k:start|Mini-M68K]] |A Motorola 68008 processor board. Requires the Multifunction Controller (MF/PIC) board for I/O (see below). Runs CP/M-68. | |
|[[:boards:sbc:sbc-188:start|SBC-188]] |An Intel/AMD 80C188 processor board. //Capable of functioning both as an an SBC and on the ECB bus.// | | |[[:boards:sbc:sbc-188:start|SBC-188]] |An Intel/AMD 80C188 processor board. //Capable of functioning both as an an SBC and on the ECB bus.// | |
|[[:boards:sbc:z180_mark_iv:z180_mark_iv|Mark IV]] |A Zilog Z180 processor board. Capable of functioning both as an an SBC and on the ECB bus. | | |[[:boards:sbc:z180_mark_iv:z180_mark_iv|Mark IV]] |A Zilog Z180 processor board. Capable of functioning both as an an SBC and on the ECB bus. SDcard & IDE-8 (for CF card) interfaces on-board. | |
|[[:boards:sbc:sbc_v2:start|SBC V2]] |A Zilog Z80 processor board. //Capable of functioning both as an an SBC and on the ECB bus.// | | |[[:boards:sbc:sbc_v2:start|SBC V2]] |A Zilog Z80 processor board. //Capable of functioning both as an an SBC and on the ECB bus.// | |
|[[:boards:sbc:6x0x-atx-6u:start|6x0x-ATX-6U]] |An MOS 6502 / Motorola 6809 processor board. //Electrically capable of functioning both as an an SBC and on the ECB bus, but ECB software support currently limited// | | |[[:boards:sbc:6x0x-atx-6u:start|6x0x-ATX-6U]] |An MOS 6502 / Motorola 6809 processor board. //Electrically capable of functioning both as an an SBC and on the ECB bus, but ECB software support currently limited// | |
|[[:boards:sbc:n8:start|N8]] |A Zilog Z180 processor board. //Electrically capable of functioning both as an an SBC and on the ECB bus, but ECB software support currently limited// | | |[[:boards:sbc:n8:n8|N8]] |A Zilog Z180 processor board. //Electrically capable of functioning both as an an SBC and on the ECB bus, but ECB software support currently limited// | |
|[[:boards:ecb:diskio-v3:start|DiskIO V3]] |A board providing floppy and IDE storage support | | |[[:boards:ecb:diskio-v3:start|DiskIO V3]] |A board providing floppy and IDE storage support | |
|[[:boards:ecb:mf-pic:start|MF/PIC]] |Multifunction Programmable Interrupt Controller support board required by the ECB Mini-68K CPU and ECB KISS-68030 CPU boards. It may also be used with the SBC v2 (Z80) to provide mode 2 interrupt vectoring. | | |[[:boards:ecb:mf-pic:start|MF/PIC]] |Multifunction Programmable Interrupt Controller support board required by the ECB Mini-68K CPU and ECB KISS-68030 CPU boards. It may also be used with the SBC v2 (Z80) to provide mode 2 interrupt vectoring. | |
|<font inherit/inherit;;#008000;;inherit>4MEM</font> |4MB expanded memory board for SBC-188. Uses EMM4MEM.sys driver. Also expands SBC-188 memory to full 640K. Expanded memory is good for a battery-backed Ramdisk. | | |4MEM |4MB expanded memory board for SBC-188. Uses EMM4MEM.sys driver. Also expands SBC-188 memory to full 640K. Expanded memory is good for a battery-backed Ramdisk. | |
| |[[:boards:ecb:adio:start|4UART]] |Quad high-speed UART interfaces to RS-232 or USB at up to 3Mbps. 2 ports are dedicated to USB; 2 ports are USB or RS-232, selectable. | |
|[[:boards:ecb:adio:start|ADIO]] |An Analog/Digital I/O Board | | |[[:boards:ecb:adio:start|ADIO]] |An Analog/Digital I/O Board | |
|[[:boards:ecb:dsky:start|DSKY]] |A Display Keyboard unit providing a hexidecimal display and numeric input keypad. | | |[[:boards:ecb:dsky:start|DSKY]] |A Display Keyboard unit providing a hexidecimal display and numeric input keypad. | |
===== "Orphaned" ECB Cards ===== | ===== "Orphaned" ECB Cards ===== |
These are ECB cards which: | These are ECB cards which: |
- Have no KiCAD or Gerber files available on the wiki | - Have no KiCAD or Gerber files available on the wiki |
- Have no community member listed as a board distributor on the [[:boardinventory|RetroBrew Computers Board Inventory]] page | - Have no community member listed as a board distributor on the [[:boardinventory|RetroBrew Computers Board Inventory]] page |
These board could be "brought back" if KiCAD/Gerber files are located, or if someone is willing to re-enter the schematic into KiCAD and re-route a new board. | These board could be "brought back" if KiCAD/Gerber files are located, or if someone is willing to re-enter the schematic into KiCAD and re-route a new board. |
|[[:boards:ecb:orphaned:active-termination:start|Active Termination]] |A board which provides Active Termination to the ECB bus | | |[[:boards:ecb:orphaned:active-termination:start|Active Termination]] |A board which provides Active Termination to the ECB bus | |
| |VDU |https://retrobrewcomputers.org/n8vem-pbwiki-archive/0/35845334/48860720/4200893/index.htm | |
===== Retired ECB Cards ===== | ===== Retired ECB Cards ===== |
===== ECB Board I/O Port Guidelines ===== | ===== ECB Board I/O Port Guidelines ===== |
<code> | ^Board^Ports^Fixed Port^ | |
00..07 4 x 4MEM boards | ^<font inherit/Courier New,Courier,monospace;;inherit;;inherit>4MEM boards x 4</font>|<font inherit/Courier New,Courier,monospace;;inherit;;inherit>00..07</font>| | | |
08..09 Dual SD card | ^<font inherit/Courier New,Courier,monospace;;inherit;;inherit>Duel SD card</font>|<font inherit/Courier New,Courier,monospace;;inherit;;inherit>08..09</font>| | | |
0C..0F ECB USB FIFO | ^<font inherit/Courier New,Courier,monospace;;inherit;;inherit>ECB USB FIFO</font>|<font inherit/Courier New,Courier,monospace;;inherit;;inherit>0C..0F</font>| | | |
20..3F IDE & Floppy controllers (DiskI/O, Dual IDE) | ^<font inherit/Courier New,Courier,monospace;;inherit;;inherit>IDE & Floppy Controllers (DISK I/O, Duel IDE)</font>|<font inherit/Courier New,Courier,monospace;;inherit;;inherit>20..3F</font>| | | |
40..7F Z180 Mark IV internal registers | ^<font inherit/Courier New,Courier,monospace;;inherit;;inherit>Z180 Mark IV internal registers</font>|<font inherit/Courier New,Courier,monospace;;inherit;;inherit>40..7F</font>| | | |
40..7F N8 Home Computer internal registers | ^<font inherit/Courier New,Courier,monospace;;inherit;;inherit>N8 Home Computer internal registers</font>|<font inherit/Courier New,Courier,monospace;;inherit;;inherit>40..7F</font>| | | |
40..4F MF/PIC – has also been at 80..8F | ^<font inherit/Courier New,Courier,monospace;;inherit;;inherit>MF/PIC</font>|<font inherit/Courier New,Courier,monospace;;inherit;;inherit>40..4F</font>| |<font inherit/Courier New,Courier,monospace;;inherit;;inherit>Has also been at 80..8F</font>| |
60..7F SBC v1/v2 on-board I/O | ^<font inherit/Courier New,Courier,monospace;;inherit;;inherit>SBC v1/v2 on-board peripherals</font>|<font inherit/Courier New,Courier,monospace;;inherit;;inherit>60..7F</font>|<font inherit/Courier New,Courier,monospace;;inherit;;inherit>Y</font>| | |
80..8F Z180 Mark IV on-board peripherals | ^<font inherit/Courier New,Courier,monospace;;inherit;;inherit>Z180 Mark IV on board peripherals</font>|<font inherit/Courier New,Courier,monospace;;inherit;;inherit>80..8F</font>| | | |
80..9F N8 Home Computer on-board peripherals | ^<font inherit/Courier New,Courier,monospace;;inherit;;inherit>N8 Home Computer on board peripherals</font>|<font inherit/Courier New,Courier,monospace;;inherit;;inherit>80..9F</font>| | | |
98..9F SCG graphics (same as N8) | ^<font inherit/Courier New,Courier,monospace;;inherit;;inherit>SCG graphics</font>|<font inherit/Courier New,Courier,monospace;;inherit;;inherit>98..9F</font>| |<font inherit/Courier New,Courier,monospace;;inherit;;inherit>Same as N8</font>| |
A0..A7 2 x RAM-Floppy cards | ^<font inherit/Courier New,Courier,monospace;;inherit;;inherit>RAM-Floppy x 2</font>|<font inherit/Courier New,Courier,monospace;;inherit;;inherit>A0..A7</font>| | | |
A8..AF PropI/O | ^<font inherit/Courier New,Courier,monospace;;inherit;;inherit>Zilog peripherals</font>|<font inherit/Courier New,Courier,monospace;;inherit;;inherit>B0..BF</font>|<font inherit/Courier New,Courier,monospace;;inherit;;inherit>N</font>| | |
C0..DF 4UART | ^<font inherit/Courier New,Courier,monospace;;inherit;;inherit>Prop I/O</font>|<font inherit/Courier New,Courier,monospace;;inherit;;inherit>A8..AF</font>| | | |
E0..EF CVDU | ^<font inherit/Courier New,Courier,monospace;;inherit;;inherit>4UART</font>|<font inherit/Courier New,Courier,monospace;;inherit;;inherit>C0..DF</font>| | | |
E0..E7 VGA3 | ^<font inherit/Courier New,Courier,monospace;;inherit;;inherit>CVDU</font>|<font inherit/Courier New,Courier,monospace;;inherit;;inherit>E0..EF</font>| | | |
F0..FF reserved for experimental boards | ^<font inherit/Courier New,Courier,monospace;;inherit;;inherit>VGA3</font>|<font inherit/Courier New,Courier,monospace;;inherit;;inherit>E0..E7</font>| | | |
F0..F3 VDU (wired port) | ^<font inherit/Courier New,Courier,monospace;;inherit;;inherit>Reserved</font>|<font inherit/Courier New,Courier,monospace;;inherit;;inherit>F0..FF</font>| |<font inherit/Courier New,Courier,monospace;;inherit;;inherit>For experimental boards</font>| |
</code> | ^<font inherit/Courier New,Courier,monospace;;inherit;;inherit>VDU (wired port)</font>|<font inherit/Courier New,Courier,monospace;;inherit;;inherit>F0..F3</font>| | | |
Downloadable: {{:boards:ecb:board_ports.pdf|Board_Ports.pdf}} | \\ |
