ECB Mini Backplane
The backplane features a power input, power switch, LED to indicate when power is on, and a 2-pin input header to connect a reset switch. On the reverse side of the PCB the ECB pin rows and columns are labelled for quick identification and a key listing the ECB signal names is provided.
The board is designed to be used either flat on a table with the cards standing up, or on its side with the backplane connectors and power switch above the ECB cards and both backplane and cards resting on the table.
Notes on Construction
If you intend to use the board lying flat with the cards standing up, fit four 3M BumpOn rubber domes on the rear to prevent scratching your work surfaces. If you intend to use the board vertically with the ECB cards lying against the desk be aware that many cards will be “upside-down”, take care to ensure the electrons don't fall out.
boards/ecb/backplane-3/start.1489857406.txt.gz · Last modified: 2017/03/18 13:16 by will
