ECB Mini Backplane
The backplane features a power input, power switch, LED to indicate when power is on, and a 2-pin input header to connect a reset switch. On the reverse side of the PCB the ECB pins are labelled for quick identification and a key listing the ECB signal names is provided.
The board is designed to be used either standing up or lying on its side with the backplane connectors and power switch above the ECB cards.
Notes on Construction
If you intend to use the board lying flat with the cards standing up, fit four 3M BumpOn rubber domes on the rear to prevent scratching your work surfaces.
boards/ecb/backplane-3/start.1489855072.txt.gz · Last modified: 2017/03/18 12:37 by will
