ECB Mini Backplane
The ECB Mini Backplane is a backplane card for the EuroCard Bus which allows up to 3 ECB cards to be connected at one time. It features a power input, power switch, LED to indicate when power is on, and a 2-pin input header to connect a reset switch. On the reverse side of the PCB the ECB pins are labelled for quick identification and a key listing the ECB signal names is provided. The board is designed to be used either standing up or lying on its side with the backplane connectors and power switch above the ECB cards.
Notes on Construction
Photographs
ecb-mini-backplane-assembled.jpgecb-mini-backplane-pcb.jpgecb-mini-backplane-inuse.jpg
boards/ecb/backplane-3/start.1489854770.txt.gz · Last modified: 2017/03/18 12:32 by will
