ECB Mini Backplane
The ECB Mini Backplane is a backplane card for the EuroCard Bus which allows up to 3 ECB cards to be connected at one time. It features a power input, power switch, LED to indicate when power is on, and a 2-pin input header to connect a reset switch. On the reverse side of the PCB the ECB pins are labelled for quick identification and a key listing the ECB signal names is provided. The board is designed to be used either standing up or lying on its side with the backplane connectors and power switch above the ECB cards.
C1, C2, C6, C7Capacitor with 0.2“ lead spacing, under 10mm diameter, under 12mm height (Builder's choice)
Panasonic 6SEPC560MX (good diameter, lead spacing is a bit narrow but fits with some “encouragement”, very low ESR)
10uF or greater MLCC
Notes on Construction
Make sure you fit the ECB sockets the correct way round! See the photographs if unsure. Ensure any electrolytic capacitors are fitted with the correct polarity (marked on the board). The power switch is optional and can be omitted simply by fitting a (reasonably thick) wire jumper in its place.
boards/ecb/backplane-3/start.1489854509.txt.gz · Last modified: 2017/03/18 12:28 by will
