R03 Errata
PIO 0
PIO 1
PIO 2
PIO 3
Initial state:
- Pin 26 (+5v) is connected to the ground plane.
- Pin 11 (gnd) is connected to +5v via C24
End state:
- Pin 26 (+5v) disconnected from ground plane and connected to +5v by wire link.
- Pin 11 (gnd) connection is changed from a VCC plane to a GND plane.
Steps:
- Cut the thermal relief links between pin 6 of IC12 (pio3) and the ground plane.
- Link pin 6 of IC12 (pio 3) to pin 2 of C12.
- Cut the link between pin 11 of IC12 (pio 3) and + pin of C24.
- Link pin 11 of IC12 (pio 3) to the GND pin of C24.
- Cut the link between pin 6 IC9 (pio 2) and pin 18 of P3.
